EasyHID and USB for Newbies??
Results 1 to 40 of 69
    Mar 2006
    Gothenburgh, Sweden
    Hi.
    Im using EasyHID and a 18f4550 to communicate with VB6.
    I use MicroCode Studio Plus and PicBasic 2.46. I download my programs using Microchip USB bootloader. And this works just fine.
    Now I want to write a program that counts how long time an input pin is activated. Typical time will be in range form about 1ms - 120ms.
    Normaly I would use "Pulsin" but what I understand the USB commands must be polled every 1ms or so. Is there another way to solve it in Basic?
    Maybe to use the timers in 4550? If so, how shall that basic code be written?
    Im not skilled enough to write the code in asm so it would be great if it is possible to do it in PicBasic.
    Thanks in advance.
    /Stefan.
    Oct 2003
    Australia
    Lightbulb
    Just revisiting this topic again....
    It seems that HID is good enough to program and set up the PIC for USB use, but one really needs to generate a VB program to interface the PC to the USB device (aka PIC device)
    I don't have VB, and was considering downloading the 60MB VB express from Microsoft.
    Does anybody have experience with VB Express?
    Does it have COMM components included? Or can you get them from a 3rd party? Prefer if they were free.... hahaha
    I'm really interested in doing a bit of serial communications between the PIC(4550) and PC over the USB link, as most PC nowdays don't even come with Serial Com ports, USB interfacing is gonning to be the way of the future.
    I don't want to go down the path of using a pre built usb 2 serial converter when a USB pic should be good enough, right?
    interfacing a PIC to a pc is still easy.. the main problem is still that you have to keep the connection by send data to PC every 10mSec or so. Not so much problem but in some case, it's a pain. some conventionnal PIC and a RS232 to USB ic is still cheap and save the day when timing is critical.
    But i'm still new in USB, there's so much things to learn before be comfortable with everything. Yeah it's more complicated than just USBIN, USBOUT, USBINIT, and USBSERVICE.. Jan Axelson's book is more than enough.
    I use Visual C++, Visual Basic 6 and , beurk Delphi, so i'd never use the VB Express as now, it should have what you need. Case not, i guess you can use the API or DLL (i don't remind) of HID maker and play 'round it.
    I had tried with VB Express but had quickly ditched it for VB6 from EBay. There were several things about VB Express; it lacks several features like Package Deployment which I require. I don't remember all the other reasons why I dropped it, but I "REALLY" didn't like it.
    Check out EBay for VB6, there were several cheap auctions for the academic versions of VB6. I ended up getting the full corporate version for just a bit more, with all the manuals and tutorials.
    Here's a NEW package for $125USD:
    http://cgi.ebay.ca/ws/eBayISAPI.dll?...m=160004563299
    This kit includes:
    *Microsoft Visual Basic 6.0 Learning Edition
    *Learn Microsoft Visual Basic 6.0 Now
    *Microsoft Visual Basic 6.0 step by step
    *Microsoft Visual Basic 6.0 Programmer's Guide
    *The MSDN Library on two CD-ROMs
    Some more learning editions:
    http://cgi.ebay.ca/ws/eBayISAPI.dll?...m=250004751173
    http://cgi.ebay.ca/ws/eBayISAPI.dll?...m=160005627793
    Here's a professional edition:
    http://cgi.ebay.ca/ws/eBayISAPI.dll?...m=300005730012
    The action includes:
    Microsoft Visual Basic 6.0 Professional Edition. One CD in Original Case.
    Microsoft Visual Studio 6.0 Service Pack 5.0 One CD in a jewled case.
    MS MSDN Libray-Visual Studio 6.0. 2 CDs in the original case.
    MS Visual Studio 6.0 PLUS PACK. 4 CDs in the original case.
    These are the full functional sets, not educational settings or demos.
    Good luck!
    Feb 2005
    Essex, UK
    Default Easy Hid Problems
    I suspect a lot of you that have posted on this thread are subscribed to it. I'm having problems with Easy HID and have posted a new subject. Obviously a lot of you guys have used it and I'm wondering what I'm doing wrong. Please chack my post out - it's driving me mad:
    http://www.picbasic.co.uk/forum/showthread.php?t=4304
    I am ONLY having problems with the PIC program on compile
    Thanks a lot
    Rob
    Default VB6 vs. VB Express
    I just got an started using VB Express. Yes, it's a bit different, but it works great. You do have to learn a new way of writing things, but it's "the new way of doing things" according to Micro$oft.
    If you use the "Upgrade Wizard", you can take your older VB6 type programs and import them into VB Express without much problem at all. VB Express uses a bunch of compatibility files to make it work with the old code just fine. Took me about 2 minutes to get an old serial port program with with VB Express...and the price was right too...
    JDG
    bigbear's Avatar
    bigbear Guest
    I am working to convert the VB file from easyHID to a REALBASIC file. I am almost there but need some help. Anyone here do anywork in realbasic? You can check out the thread here:
    http://forums.realsoftware.com/viewt...b170185ab69b24
    I will post the files for anyone who wants them when the conversion is done. Advantage of RB is it compiles into Windows, Mac OS, and Linix. Not sure if the app will work in non windows apps, but I'll find out. Looks like it should work.
    Apr 2008
    Unhappy
    Like a lot of you I’m just starting to migrate some of my applications to USB. I’ve tried to us EasyHID to help me get started. I’ve read threw this post and it makes sense what I’m reading. My problem is that when I try to compile the PBP file it creates I get the compilation error
    ERROR: Macro USBINIT? not found in macro file.
    ERROR: Macro USBSERVICE? not found in macro file.
    ERROR: Macro USBIN?CBBL not found in macro file.
    ERROR: Macro USBOUT?CBBL not found in macro file.
    I’ve seen several posts’ that ask this question and I haven’t seen a good answer to what is causing it and how to fix it. I suspect it has to do with directory structure.
    I’m using MCSP 3.0.0.5 and PBP 2.47.
    PIC18F4550
    Please help,
    Feb 2005
    Essex, UK
    Hi mjwaldner,
    Using Microcode Studio, make sure you have the correct chip selected, 18F4550. The editor sometimes defaults to a different IC when you open it - this has caught me out a couple of times!
    Make sure that all the files that were generated by EasyHID are in the same folder as the file you are trying to compile - see attached image
    Let us know how you get on
    Cheers
    Rob
    Apr 2008
    Red face
    Thanks Rob,
    I started over form scratch and it worked this time. I must have moved something to the wrong directory.
    My next question is. Should the computer recognize the USB device and try to install it automatically? I understand that I will need to work on the PC software to make it work but when I plug the USB cable into the PC nothing happens. It doesn’t try to install. I haven’t modified the software the Easy HID created. I just programmed it to the PIC 18F4550. Is there more code needed to initialize it.
    I’m just taking baby steps threw this. Any information is helpful.
    Matt
    In case it have already worked and if you haven't change the PID, VID and all other settings, if you plug the device you're not going to have any bubbles on the task bar.
    If you want some, you'll need to uninstall the device. That's pretty easy to do with USBDeview
    http://www.nirsoft.net/utils/usb_devices_view.html
  1. Simple USB Comms Problem
    Last Post: - 6th January 2010, 20:17
  2. EasyHID max usb buffer size
    By jizyjuice in forum USB
    Last Post: - 29th November 2007, 05:12
  3. Speed of USB EasyHID and Time problem
    By sjohansson in forum USB
    Last Post: - 18th January 2007, 22:21
  4. USB and EasyHID Problems
    By Rob in forum USB
    Last Post: - 6th January 2007, 18:19
  5. USB PIC without USB Connection
    Last Post: - 26th December 2005, 17:39
