EasyHID and USB for Newbies??
Results 1 to 40 of 69
Threaded View
  1. #11
    Aug 2005
    Los angeles
    Unhappy Vb6 to Vb.net
    I am using easyHID sofware to generate a Visual basic code 6.0. I have the visual basic .net installed. So when i copy the file from vb.6 to vb.net , Vb.net upgrades the file to the .net configuration.Except for one thing that gave me an error:it's the upgrade warning about adding a delegate.
    Public Function ConnectToHID(ByVal pHostWin As Integer) As Boolean
    FWinHandle = pHostWin
    ConnectToHID = hidConnect(FWinHandle)
    'UPGRADE_WARNING: Add a delegate for AddressOf WinProc Click for more: 'ms-help://MS.VSCC.2003/commoner/redir/redirect.htm?keyword="vbup1048"'
    FPrevWinProc = SetWindowLong(FWinHandle, GWL_WNDPROC, AddressOf WinProc)
    End Function
    I couldn't figure out how to fix it, Any idea?? here is what the help menu suggested :
    In Visual Basic 6.0, the AddressOf operator was used to pass the address in memory of a function to an API procedure that takes a function pointer as an argument.
    In Visual Basic .NET, the AddressOf operator must be used with a Delegate type. Delegates allow Visual Basic .NET to maintain a pointer to a function even if the function itself has already been garbage-collected.
    The following example illustrates how a callback function that uses AddressOf is upgraded:
    ' Visual Basic 6.0
    Declare Function SetWindowLong Lib "USER32.DLL" Alias "SetWindowLongA" (ByVal hwnd As Long, ByVal attr As Long, ByVal lVal As Long) As Long
    Sub SubClassWindow(ByVal hwnd As Long)
    If PrevProcPtr = 0 Then
    PrevProcPtr = SetWindowLong(hwnd, GWL_WNDPROC, AddressOf SubClassProc)
    End If
    End Sub
    ' After upgrade to Visual Basic .NET
    Declare Function SetWindowLong Lib "USER32.DLL" Alias "SetWindowLongA"(ByVal hwnd As Integer, ByVal attr As Integer, ByVal lVal As Integer) As Integer
    Sub SubClassWindow(ByVal hwnd As Integer)
    ' UPGRADE_WARNING: Add a delegate for AddressOf SubClassProc.
    End If
    End Sub
    What to do next
    Add a delegate for the AddressOf operator, and change the parameter of the function declaration to the Delegate type:
    Delegate Function SubClassProcDelegate(ByVal hwnd As Integer, ByVal msg As Integer, ByVal wParam As Integer, ByVal lParam As Integer) As Integer
    Declare Function SetWindowLong Lib "USER32.DLL" Alias "SetWindowLongA" (ByVal hwnd As Integer, ByVal attr As Integer, ByVal lVal As SubClassProcDelegate) As Integer
    End If
    End Sub
    Thank you in advance
  1. Simple USB Comms Problem
    Last Post: - 6th January 2010, 21:17
  2. EasyHID max usb buffer size
    By jizyjuice in forum USB
    Last Post: - 29th November 2007, 06:12
  3. Speed of USB EasyHID and Time problem
    By sjohansson in forum USB
    Last Post: - 18th January 2007, 23:21
  4. USB and EasyHID Problems
    By Rob in forum USB
    Last Post: - 6th January 2007, 19:19
  5. USB PIC without USB Connection
    Last Post: - 26th December 2005, 18:39
