EasyHID and USB for Newbies??
Results 1 to 40 of 69
Threaded View
  1. #11
    Aug 2005
    Hi Robert
    When you say more PC side, yep you are correct, you will need a copy of Visual Basic for the code example above and at least know the basics of creating a windows application.
    There are a number of different development packages out there for writing your own windows applications, such as Visual Basic, Delphi, Visual C++ or the newer .NET .
    The sample code created by easy HID is for the first 3 development platforms listed bove.
    So first you need to get a development package, then you need to learn how to use it. Visual Basic to me has always been the easiest, have played with Delphi a little.
    When you have your development package you can then start learning how to write your own applications, and there are literaly thousands of development websites where other guys have already came across any problems that you will encounter and also would of posted sample code to help you out.
    Sean.
    Quote Originally Posted by Demon
    Thanks Sean, but like I posted back on Jan 10th that's not quite it. There's gotta be more required on the PC side. That code just doesn't sit in a text file, it has to be compiled or something. That's where all the USB threads come up short. Either everyone is assuming a whole bunch about what we 'should' know, or I'm too dense and just not getting something obvious...
    http://www.cncdudez.co.uk
  1. Simple USB Comms Problem
    Last Post: - 6th January 2010, 20:17
  2. EasyHID max usb buffer size
    By jizyjuice in forum USB
    Last Post: - 29th November 2007, 05:12
  3. Speed of USB EasyHID and Time problem
    By sjohansson in forum USB
    Last Post: - 18th January 2007, 22:21
  4. USB and EasyHID Problems
    By Rob in forum USB
    Last Post: - 6th January 2007, 18:19
  5. USB PIC without USB Connection
    Last Post: - 26th December 2005, 17:39
