I am developing using the easyPIC3 board and the bootloader works just fine with a serial cable on COM1. If I try to use a USB-Serial cable - it asks for a reset, but nothing happens. Same hardware set up on the PIC side, just replaced the direct serial cable with the USB-SERIAL device.
Does the bootloader work with a USB to Serial convertor plugged into the PC?
I will need this to work as I will be reloading the PIC in the field from a notebook - which doesn't have a comm port.
Any help much appreciated
