Midi cc controller!
Results 1 to 5 of 5
    Alaskanphoenix's Avatar
    Alaskanphoenix Guest
    Default Midi cc controller!
    Hi!
    I am using a 16f84a with 20mhz to control 10 pots and send the corresponding midi cc message, but the pot command seems to be too slow and if i move the pot very fast it skips many messages! The 10kb pots are connected with a 0.1uf cap. I don't want to change the 16f84a because i have a bunch of them,so how could i fix the problem?
    thanks in advance
    Worst case scenario:
    pot at 10K with 100nF gives 1msec time constant.
    10 pots x 1msec gives 10msec plus your commands in the programm.
    So you cannot get rapid reply with this method. A PIC with ADC I 'm afraid is what you need here.
    Thanks a a lot Ioannis.
    If i substitute the cap with a smaller one?
    Yes you can I suppose use smaller caps but I have not checked it. I guess from the idea of implementing that kind of adc the range is limited. I would not try smaller than half the 100nf. I feel that you may have to use a fast analog to digital converter or at least try a PIC with an adc.
    I think i'll try some other pic like 16f88 or better the 16f876!
    thanks a lot
  1. Microstepper controller
    By aratti in forum Schematics
    Last Post: - 3rd January 2015, 16:52
  2. Midi, Interrupts and Pic better than SX28?
    By Lajko in forum mel PIC BASIC Pro
    Last Post: - 27th September 2008, 00:26
  3. 12f675 and midi!
    By Alaskanphoenix in forum mel PIC BASIC Pro
    Last Post: - 14th April 2006, 16:25
  4. Dedicated LCD Controller question
    By chuckles in forum mel PIC BASIC Pro
    Last Post: - 27th February 2006, 14:44
  5. DC Brushless Motor controller?
    By forgie in forum Off Topic
    Last Post: - 4th February 2006, 14:02
