IF or SELECT
Results 1 to 2 of 2
Thread: IF or SELECT
    Jul 2005
    Default IF or SELECT
    whats faster to execute this "IF" statement or this "select" statement? (and why?)
    IF RECADD = 0 THEN outr0
    IF RECADD = 1 THEN outr1 ' if request is for RECADD#1 then goto RECADD#1 routine
    IF RECADD = 2 THEN outr2 ' if request is for RECADD#2 then goto RECADD#2 routine
    IF RECADD = 3 THEN outr3 ' if request is for RECADD#3 then goto RECADD#3 routine
    IF RECADD = 4 THEN outr4 ' if request is for RECADD#4 then goto RECADD#4 routine
    IF RECADD = 5 THEN outr5 ' if request is for RECADD#5 then goto RECADD#5 routine
    IF RECADD = 6 THEN outr6 ' if request is for RECADD#6 then goto RECADD#6 routine
    or
    SELECT CASE RECADD
    CASE 1
    GOTO outr1
    CASE 2
    GOTO outr2
    CASE 3
    GOTO outr3
    CASE 4
    GOTO outr4
    CASE 5
    GOTO outr5
    CASE 6
    GOTO outr6
    END SELECT
    Sep 2005
    Campbell, CA
    For things like this, I use a little code timer that I wrote. It uses Timer0 to measure execution time of code snippets.
    Presently, it is designed for use with an 18F8720 running at 20Mhz, but it could be easily modified for other processors or speeds.
    DEFINE OSC 20 ' Set for 20Mhz operation
    DEFINE NO_CLRWDT 1 ' Don't waste cycles clearing WDT
    DEFINE _18F8720 1
    DEFINE HSER_RCSTA 90H
    DEFINE HSER_TXSTA 20H
    DEFINE HSER_CLROERR 1
    DEFINE LOADER_USED 1
    Define USE_LFSR 1
    DEFINE ADC_BITS 10
    DEFINE ADC_CLOCK 2
    DEFINE ADC_SAMPLEUS 50
    DEFINE I2C_HOLD 1
    DEFINE I2C_SLOW 1
    TRISC = %10111111 ' Hardware serial port on PORTC.7,PORTC.6
    PSPCON = %00000000 ' No PSP
    MEMCON = %10000000 ' No External Memory
    CMCON = %00000111
    ' No Comparator used, turn it off
    TXSTA1.2 = 1
    SPBRG = 129
    INTCON = $80 ' Turn off interrupts
    T0CON = %10001000 ' No Prescaler,16 bit Timer 0
    TimerValue VAR WORD
    RealTime VAR WORD
    OverFlow VAR BYTE
    Prescale VAR BYTE
    DummyVal VAR Byte
    ' Put Variables required by program here
    Restart:
    'Put code to be timed here
    Time_It:
    TimerValue.LowByte = TMR0L
    TimerValue.Highbyte = TMR0H
    IF INTCON.2 = 1 THEN
    INTCON.2 = 0
    OverFlow = OverFlow + 1
    If OverFlow = 1 THEN
    T0CON = %10000010
    Prescale = 8
    IF OverFlow = 2 THEN
    HSEROUT ["Execution time too long - choose another prescaler value",13,10]
    GOTO RESTART
    HSEROUT ["Execution Time = ",#(TimerValue * Prescale), " Cycles, ",#((TimerValue/5)*Prescale)," Microseconds",13,10,10]
    HSEROUT ["Press any key to restart",13,10]
    HSERIN [DummyVal]
    GOTO Restart
    Charles Linquist
  1. Sony SIRC IR Issue
    By Ryan7777 in forum mel PIC BASIC Pro
    Last Post: - 8th August 2015, 09:10
  2. Multiple "AND"'s in select case?
    By polymer52 in forum mel PIC BASIC Pro
    Last Post: - 1st January 2010, 20:10
  3. Code Issue - select case or 'if' issue - not sure why
    Last Post: - 7th October 2007, 09:52
  4. select case question
    By ronjodu in forum mel PIC BASIC Pro
    Last Post: - 12th March 2006, 11:01
  5. Select Case syntax
    By keithdoxey in forum mel PIC BASIC Pro
    Last Post: - 27th September 2005, 20:19
