ON INTERRUPT problem
Results 1 to 5 of 5
    If you're trying to gosub to something in "Page 15", then it might be a problem.   With the 18F processors, there aren't any Pages. Program Memory is just one big block of Flash. There is a BANK 15, but that's RAM.
    If things are freezing, or restarting, it could be from a "Stack Over/Underflow", or Interrupt Loop.
    Some things to check ...
    Use DISABLE before, and ENABLE after the ISR. AND, any subroutines that you GOSUB to from the ISR.
    The ISR must "RESUME", not RETURN.
    Make sure you reset the Interrupt Flag(s) before resume-ing.
    Never jump out of a Subroutine using GOTO, always RETURN
    Here's some more Stack information from Bruce.
    http://www.picbasic.co.uk/forum/showthread.php?p=2686
    juszuf's Avatar
    juszuf Guest
    Default Finally....
    I was able to fix the program, i did not use disable before ISR, so thanks a LOT for your advise!!!
    Bye!
  1. problem using GOSUB under interrupt
    By fobya71 in forum mel PIC BASIC Pro
    Last Post: - 5th March 2010, 19:52
  2. Problem with Interrupt on PIC18F4620 PORTB
    By rookie in forum Off Topic
    Last Post: - 22nd March 2007, 01:34
  3. Interrupt Problem
    Last Post: - 16th November 2005, 20:58
  4. Interrupt stack overflow problem with Resume {label}
    By Yuantu Huang in forum mel PIC BASIC Pro
    Last Post: - 3rd May 2005, 01:17
    Last Post: - 6th March 2005, 01:07
