Hi, I'm trying out different things with PICBasic Pro and one of the programs I'm trying to write is a 3-to-8 Decoder. The problem I'm having is with the inputs on PortA. No matter what I do, I can't get them to work. I'm using a 16F628A PIC with a 5V+ fed through a 10k resistor to make my input high. If I use some of PortB as Input, those work, it's just PortA I can't seem to use.
Heres the start of my program. It doesn't actually decode yet, I'll finish that once I get these dang Inputs to work.
BlackNoir
'3-to-8 Decoder
'Initialize variables needed in program
B2 VAR BYTE
'Initialize Port(s)
TRISB = 0 'set port B pins as output (00000000)
TRISA = %00000111
Loop1:
B2 = 0
IF PORTA.0 = 1 Then
B2 = B2 + 1
EndIF
IF PORTA.1 = 1 Then
B2 = B2 + 2
EndIF
IF PORTA.2 = 1 Then
B2 = B2 + 4
EndIF
PORTB = B2
GoTo Loop1
