3-to-8 Decoder Program
Results 1 to 3 of 3
    BlackNoir's Avatar
    BlackNoir Guest
    Default 3-to-8 Decoder Program
    Hi, I'm trying out different things with PICBasic Pro and one of the programs I'm trying to write is a 3-to-8 Decoder. The problem I'm having is with the inputs on PortA. No matter what I do, I can't get them to work. I'm using a 16F628A PIC with a 5V+ fed through a 10k resistor to make my input high. If I use some of PortB as Input, those work, it's just PortA I can't seem to use.
    Heres the start of my program. It doesn't actually decode yet, I'll finish that once I get these dang Inputs to work.
    BlackNoir
    '3-to-8 Decoder
    'Initialize variables needed in program
    B2 VAR BYTE
    'Initialize Port(s)
    TRISB = 0 'set port B pins as output (00000000)
    TRISA = %00000111
    Loop1:
    B2 = 0
    IF PORTA.0 = 1 Then
    B2 = B2 + 1
    EndIF
    IF PORTA.1 = 1 Then
    B2 = B2 + 2
    EndIF
    IF PORTA.2 = 1 Then
    B2 = B2 + 4
    EndIF
    PORTB = B2
    GoTo Loop1
    Apr 2005
    Porta is normally set to comparator.
    Use this:
    CMCON=$07 'NO comparator on PORTA
    and pins become bidirectional.
    Read carefully the datasheet and how to set mclr pin.
    bye
    roberto
    BlackNoir's Avatar
    BlackNoir Guest
    That did it! Thanks roberto!!
  1. CTCSS Tone Decoder Sample Program
    By sozkarabacak in forum General
    Last Post: - 20th October 2009, 07:15
  2. Replies: 4
    Last Post: - 15th April 2009, 02:54
  3. Making Program Code Space your playground...
  4. Someone help me to simplify this
    By thrix in forum General
    Last Post: - 21st February 2004, 06:01
  5. Help wanted..
    By thrix in forum mel PIC BASIC Pro
    Last Post: - 18th February 2004, 00:44
