I have fried Dallas 1-wire parts before inserting them backwards for only a few seconds.
Try something super simple like reading & displaying the raw temp value returned. If that doesn't work, it's probably toast.
In engineering, you're allowed to make lots of mistakes, as long as the next EC (engineering change) solves the problem.
If I ground the DQ pin I get all 1's. When I attach DQ to the pic I get a Raw reading of 170. The problem is its still at 170 after several minutes in the freezer. I'm thinking its dead.
I know this is an old post - but I though I might add what I discovered as it might help someone else in this position.
I had a similar situation using Bruce Reynolds demo code. After a load of time spent trying a whole lot of stuff including swapping sensors I found this -
When the DS18B20 is running in Parasitic Power mode (ie VCC input is tied to GND) then it cannot pull the DQ line high to notify the conversion is in progress.
I reconnected the Vcc on my DS18B20 to +5 and now it runs like a charm.
Hope this helps someone else !
Bill.
BTW my sensor turned out to be dead.New sensor, same code...all was well.
