After the calculation update I'm coming up with 0F.
Here are my defines:
@ DEVICE pic16F88, HS_OSC ' System Clock Options
@ DEVICE pic16F88, WDT_ON ' Watchdog Timer
@ DEVICE pic16F88, PWRT_ON ' Power-On Timer
@ DEVICE pic16F88, BOD_ON ' Brown-Out Detect
@ DEVICE pic16F88, MCLR_ON ' Master Clear Options (OFF=Internal/ON=External via resistor)
@ DEVICE pic16F88, LVP_OFF ' Low-Voltage Programming
@ DEVICE pic16F88, CPD_OFF ' Data Memory Code Protect
@ DEVICE pic16F88, PROTECT_OFF ' Program Code Protection
' // Fuses/Crystal Setup //
DEFINE OSC 20 ' 20mhz XTAL (change notes above)
FLAGS=0 ' Reset all flags
CMCON=%00000111 ' Disable Comparators
ANSEL=%00000000 ' force RB6 and RB7 digital (16F88 only)
ADCON0=%00000000
TRISA=%11100000 ' PORTA set to Output/Input
TRISB=%00000000 ' PORTB all set to Input
OPTION_REG.7=0 ' 0=Enable Weak Pull-Ups on PortB
INTCON=%11000000 ' enable global and peripheral interrupts (11000000)
' // USART Intiz/Setup //
DEFINE HSER_BAUD 9600 ' 9600 Baud USART
DEFINE HSER_RCSTA 90h ' Enable USART RX
DEFINE HSER_TXSTA 24h ' Enable USART TX
DEFINE HSER_CLROERR 1 ' Clear all USART errors as they happen
' // I2C Intiz/Setup //
DEFINE I2C_SLOW 1 ' Compenstate for 20mhz clock when writing to DS1307
SCL VAR PORTB.4 ' I2C clock location
SDA VAR PORTB.1 ' I2C data location
temperature VAR WORD ' Temperature byte array
Stat VAR BIT ' Busy or not bit
' // Port Settings //
DQ VAR PORTB.6 ' One-wire data pin "DQ" on PortB.6
