RGB Christmas Lights
Results 1 to 13 of 13
    Jun 2005
    Wisconsin
    Cool idea, btw you can run more than 32 devices. Some of the newer RS-485 transceivers allow up to 128.
    Nov 2004
    Excellent! Do you have a part number?
    32 was partly because I didn't want to load the bus too much, partly because of cost for the entire rig and partly because I only have so much balcony...
    Jun 2005
    Wisconsin
    Off the top of my head the maxim MAX13442E, MAX13443E, MAX13444E should fit the bill.
    BTW are you posting your PicBasic code on the website?
    Nov 2004
    I really should post the code, but I'd like to tweak it a bit first.
    Some thoughts -
    My design as it stands is way, way too expensive. I used a crystal per chip because I knew the circuit was stable and would work without any optimization. I'd love to move to something based on a 12F529 or similar, using an internal oscillator.
    I haven't tried it yet, but I suspect that even with some heavy assembly code, it would be a challenge to decode full-out DMX and run the PWM code at the same time.
    One solution would be to have a crystal-driven PIC receive DMX, grab data starting at the appropriate start code, and re-transmit the required channels at a lower speed.
    A string of 48 pixels spaced every 6" results in a string 25' long.
    48 pixels x 3 colors/pixel x 8 bits/color x 30 updates/second equals 34,560 bits/second. Or 4.32 KB/s. Plus some start bits and stop bits.
    And I suspect that a '529 could receive at 4800 reliably using the internal oscillator. Program the PIC to use Artistic License's BAM control scheme (google it) and the processor overhead drops tremendously. Maybe this could all fit on a 10F part...
    I'm also not sure if it's feasable to run a single-ended serial signal 48 feet and maintain signal integrity with unshielded cable and 48 hi-z taps.
    If it is, I could save even more money by eliminating the RS-485 receiver at each node.
    Anyone done something similar?
    The LEDs are still happiest at 70 mA, so direct drive is out.
    Ideally, a pixel would contain a '529, 3 x drive transistors, a decoupling capacitor and current limiting resistors.
    The current rig uses 18 gauge cable for power and ground and 1 pair+shield for the data connection.
    If I could hit $2 or even $3 per pixel, I'd be deleriously happy.
    Hmmmm...
    Anyone interested in collaborating on a project for next year?
    John
    Jun 2005
    Wisconsin
    How about CAN buss or Dallas one-wire to each of the nodes? You would then have 1 master that would convert DMX to CAN buss/one-wire.
    Nov 2004
    Interesting - I'm only slightly familiar with CAN and the one-wire protocol.
    I was thinking also of implementing a self-clocking protocol ala Manchester to handle the communication. Would be nice to run only 3 wires between each pixel.
    Synchronous serial would also be fast, but it adds an additional wire...
    Jun 2005
    Wisconsin
    One-wire is super easy. You only really need messages sent when changes occur. The downfall is it is half-duplex. That being said you are basically running half-duplex now.
    The reason I suggested CAN is because it is similar to RS-485 in that it uses two wires. You then have a full duplex network.
    http://www.interfacebus.com/Design_Connector_CAN.html
    BTW what type of container did you use for each node?
  1. My code for TV remote and MIBAM for RGB control
    By idtat in forum Code Examples
    Last Post: - 12th January 2013, 21:52
  2. Top christmas projects star
    By rickyD in forum mel PIC BASIC
    Last Post: - 20th July 2008, 09:55
  3. Scale 8bit ADC RGB LED voltmeter
    By Ryan7777 in forum mel PIC BASIC Pro
    Last Post: - 22nd February 2008, 04:37
  4. Happy Christmas
    By Adrian in forum mel PIC BASIC Pro
    Last Post: - 24th December 2007, 15:58
  5. Slowing Down RGB PWM Routine
    Last Post: - 8th March 2005, 10:22
