18F2525 ADC Accuracy
Results 1 to 3 of 3
    Sep 2005
    Default 18F2525 ADC Accuracy
    I am seeing a number jump of 144 to 155 on my analog conversions of 5VDC with a 740 millivolt input. I don't see the input changing but the conversion seems to be not as accurate as I would like it to be. I am using a 10 bit result and a 4mhz crystal.
    Is this normal or do I have some settings hosed up?
    It's very normal to see AD values jump if you're not using a filter circuit on the input.
    Try a filter something like this;
    AD input
    o-----/\/\/\/\---1K--- external analog input
    |---| |---0.1uF---gnd
    There are other simple tricks like using sleep mode, and filters on Vref for noisy power rails.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Sep 2005
    Default Thank you
    I am testing right now and it seems to have cut the jumping around in half. I thank you for your help as this has been driving my nuts for the last week.
  1. Stable Adc Reading Routine
    By gebillpap in forum General
    Last Post: - 13th May 2015, 03:18
  2. 10 bit ADC display on LCD using 16f873
    By pr2don in forum mel PIC BASIC
    Last Post: - 6th March 2010, 19:29
  3. Can't get ADC to loop
    By TravisM in forum mel PIC BASIC
    Last Post: - 11th October 2009, 16:33
  4. ADC value with 2 decimals on an LCD
    Last Post: - 2nd December 2005, 16:54
  5. 12F675 ADC 'Issues'
    By harrisondp in forum mel PIC BASIC Pro
    Last Post: - 31st March 2005, 02:55
