PIC18 Config Problems
Results 1 to 5 of 5
Threaded View
  1. #2
    and when you comment the config fuse line every error messages disapear?
    If so, did you also tried to move your config fuses to the .INC file?
    If the problem is still there, can you attach your code here (or send me a PM) to see what can we do for you?
    As i heard, this will be fix in the next PBP version. In the meantime i create new .INC file and New device in MCS(with brief project name name). This works as it's suppose to.
  1. Presetting Configuration Fuses (PIC Defines) into your Program
    Last Post: - 15th December 2013, 10:54
  2. A/D conversion with PIC18F67J50
    By ScaleRobotics in forum mel PIC BASIC Pro
    Last Post: - 8th May 2009, 02:48
  3. 18F4550 Bootloader enter via eeprom setting
    By bradb in forum mel PIC BASIC Pro
    Last Post: - 23rd November 2008, 00:51
  4. Error 0X0000008E when connecting a 18F2550 USB HID
    By FranciscoMartin in forum USB
    Last Post: - 16th October 2008, 18:20
  5. Installation sequence
    By Demon in forum General
    Last Post: - 11th July 2006, 04:56
