Using a optical coder
Results 1 to 23 of 23
    Dec 2005
    Default Using a optical coder
    Hello all
    In my new project I will use a optical coder for to know the position of tool (lathe)
    Optical coder is a 300 pulses/turn
    A full rotation of my lathe is equal 5 millimetres
    A pulse >>> 1,6/100 millimeters
    First problem
    I dont' know how to write this piece of code currently I calculate only the integer,a starting point please?
    Hi debutpic,
    Here's one way to do it.
    Pulse_Rev  CON  300  ' Pulses per Rev
    Dist_Rev   CON  500  ' Distance per Rev in mm*100
    Position   VAR  WORD
    Position = Compteur * Dist_Rev
    Position = DIV32 Pulse_Rev
    And, Ingvar will be along shortly to show you how to do it with "*/"
    Dec 2005
    he he It work fine Darrel !!
    perhaps a another question,the optical coder has only one output TTL.
    I count the pulses with the pin RB0/INT but how to know if it turns in a direction or the other?
    Unless you have some other way of knowing which way it's going, I don't think you can.
    If it needs to keep track of absolute position in both directions, you'll probably need a "Quadrature Encoder".
    Talking
    I try hard not to ......
    Dec 2005
    Hello all
    1) Which is the method of programming used for to know the directions of rotation with these optical coders?
    2)the next opticals coders agree?
    thank's
  1. 2 Beam Optical Pulse Generator
    By WOZZY-2010 in forum Schematics
    Last Post: - 6th April 2010, 04:03
  2. Home made optical rencoder issues
    By Elnino in forum mel PIC BASIC Pro
    Last Post: - 27th November 2009, 22:17
  3. USB Optical mouse as motor encoder
    By RodSTAR in forum mel PIC BASIC Pro
    Last Post: - 24th August 2008, 15:09
  4. optical voice link
    Last Post: - 18th May 2008, 21:11
  5. Using the optical sensor from a ball mouse
    By lsteele in forum General
    Last Post: - 5th September 2007, 16:45
