any ideas from PIC basic experts
Results 1 to 6 of 6
    capix's Avatar
    capix Guest
    Quote Originally Posted by arniepj
    the timer interrupt and accumulate ticks.
    hmm...i see...thanx for ur ideas i will try to check the example of timer interrupt...to tell the truth im still novice at the pic basic pro...basically how do i use the timer interrupt to implement to this code?
    If I understand your desired function correctly, maybe this idea?
    counter var byte ' a counter for the alarm condition
    mainloop:
    gosub getA ' get the range value
    'display the bargraph and value here
    if a<15 then
    counter=counter+1 'if range is low increment counter
    counter=0 'otherwise reset the counter
    if counter>150 then
    high led 'if the counter has exceeded 150 the turn the alarm on
    low led ' turn the alarm off
    pause 100 ' wait 1/10 sec
    goto mainloop ' do it again
    you might have to add a little code to prevent counter from rolling over to 0, depending on your application.
    This should force the alarm on after 15 continuous seconds of low range condition., and turn the alarm off immediately that the range exceeds 15
    capix's Avatar
    capix Guest
    dear arniepj
    i have try what u had told me...looks like its works but why my LED keep blinking when its countdown the numbers and the countdown doesnt start at 15sec but it start randomly sometime its start at 3 sometime 10...
    here's the code:
    ' include .bas file
    Include "MODEDEFS.bas"
    INCLUDE "LCDbar_INC.bas"
    define OSC 4
    ' Define LCD connections
    DEFINE LCD_DREG PORTC ' LCD Data Port
    DEFINE LCD_DBIT 0 ' Starting Data Bit
    DEFINE LCD_RSREG PORTD ' Register Select Port
    DEFINE LCD_RSBIT 0 ' Register Select Bit
    DEFINE LCD_EREG PORTD ' Enable Port
    DEFINE LCD_EBIT 1 ' Enable Bit
    DEFINE LCD_BITS 4 ' Data Bus Size
    DEFINE LCD_LINES 2 ' Number of Lines on LCD
    DEFINE LCD_COMMANDUS 2000 ' Command Delay time in uS was 2000
    DEFINE LCD_DATAUS 50 ' Data Delay time in uS was 50
    ' Allocate variables
    a var byte
    Loop1 VAR word
    Loop2 VAR word
    Delay VAR word
    countD Var Word
    second var byte
    ticks var byte
    update var byte
    i var byte
    LED var PORTB.7
    @ device WDT_OFF
    second = 0
    ticks = 0
    update = 1
    OPTION_REG = $55 ' Set TMR0 configuration and enable PORTB pullups
    INTCON = $c0 ' Enable TMR0 interrupts
    On Interrupt Goto tickint
    TRISA = %11111111
    ADCON1 = %00000000 ' Set PortA 0, 1, 3 to A/D inputs
    Pause 100 ' Wait for LCD to start
    Goto main ' Skip subroutines
    low PORTB
    Lcdout $fe,1 ' Clear LCD screen
    Lcdout "Range" ' Display Hello
    Lcdout $fe,$c0+6 ' Clear LCD screen
    Lcdout "Controller"
    Pause 5000 ' Wait .5 second
    Lcdout $fe,1
    Lcdout $fe,$c9 ' Clear LCD screen
    Lcdout "Ver 1.0"
    Delay = 110
    LCDOUT $FE,1,"LOADING"
    Pause 1000
    FOR Loop1 = 0 to 100
    ;syntax-BARgraph Value, Row, Col, Width, Range, Style
    @ BARgraph _Loop1, 2, 0, 16, 100, lines
    GOSUB ShowValue
    PAUSE Delay
    NEXT Loop1
    PAUSE 2000
    mainloop:
    Gosub geta ' Get A value
    Delay = 35
    Lcdout $fe,1,"a = " ' Send to LCD
    FOR Loop1 = a to a
    @ BARgraph _Loop1, 2, 0, 16, 30, lines
    GOSUB Show_a
    PAUSE Delay
    NEXT Loop1
    if (a<15) then gosub mainloop2
    if (a>14) then mainloop
    FOR Loop1 = a to a STEP -1
    GOSUB Show_a
    PAUSE Delay
    NEXT Loop1
    Goto mainloop ' Do it forever
    geta: ADCIN 0, a ' Read channel 0 to adval
    pause 15
    a = a / 9 + 2
    mainloop2:
    Gosub geta
    if (a<15) then decmin
    chkup: If update = 1 Then
    LCDOUT $fe,1,$c0," countdown : ", dec second
    update = 0 ' Screen updated
    Endif
    Goto mainloop2 ' Do it all forever
    decmin: second = second - 1 ' Decrement minutes
    If second >= 15 Then
    second = 14
    Endif
    pause 900
    Goto debounce
    debounce: ' Debounce and delay for 250ms
    For i = 1 to 25
    Pause 10 ' 10ms at a time so no interrupts are lost
    Next i
    update = 1 ' Set to update screen
    Goto chkup
    ' Interrupt routine to handle each timer tick
    disable ' Disable interrupts during interrupt handler
    tickint:
    ticks = ticks + 1 ' Count pieces of seconds
    If ticks < 61 Then tiexit ' 61 ticks/second (16.384ms per tick)
    ' One second elasped - update time
    ticks = 0
    second = second + 1
    second = 0
    Endif
    update = 1 ' Set to update LCD
    tiexit: INTCON.2 = 0 ' Reset timer interrupt flag
    Resume
    ShowValue
    LCDOUT $FE,$80+12,DEC BAR_value,"%"
    Show_a
    LCDOUT $FE,$80+4,DEC BAR_value," ","cm range"," "
    capix's Avatar
    capix Guest
    Quote Originally Posted by dmairspotter
    thanx dmairpotter...
  1. Sending Commands from Visual Basic about IR to Pic
    By tne_de in forum mel PIC BASIC Pro
    Last Post: - 29th April 2009, 07:09
  2. Loop with two motor and 2 sensors
  3. using AND as an IF statement
    By dw_pic in forum mel PIC BASIC
    Last Post: - 8th June 2006, 19:05
  4. vb6 to pic basic
    By Darrenmac in forum mel PIC BASIC Pro
    Last Post: - 19th December 2005, 02:56
  5. The Ultimate PIC Basic
    By picnaut in forum PBP Wish List
    Last Post: - 9th November 2004, 23:10
