Computer Fan RPM Sensor Reading
Results 1 to 8 of 8
    Default Computer Fan RPM Sensor Reading
    Has anyone written code to read the RPM from a computer fan. I think they use a hall sensor but I'm not sure.
    Yes I have. I wrote a test program to do just exactly that. I will post the basics of it tomorrow.
    That would be great Dave. I'm curious as to how you did it. I want to PWM some fans based on temperature but I need to know the RPM so I don't get them down to the stall point.
    Coka, Here is a small program I experimented with to do the fan RPM readout. The pulse output from the fan needs to be pulled up to 5 volts. At least on the 5 or so different fans I tryed. Enjoy...
    ' PROGRAM: FREQTEST.bas
    ' WRITTEN BY DAVID PUROLA 9/18/2003
    ' WRITTEN FOR PIC18F452-I/L MICROPROCESSOR
    ' MODIFIED FOR NEW HARDWARE PCB #:211976.REV.1
    DEFINE OSC 40 'OSCILLATOR = 40 Mhz.
    DEFINE LOADER_USED 1 'USE BOOT LOADER
    DEFINE NO_CLRWDT 1 'DO NOT INSERT CLRWDT's
    DEFINE BUTTON_PAUSE 20 '20 Ms. DELAY FOR BUTTON USE
    DEFINE LCD_DREG PORTD 'LCD DATA BUS ON PORT D
    DEFINE LCD_DBIT 4 'LCD DATA BUS ON PORTD.7:4
    DEFINE LCD_RSREG PORTD 'R/S REGISTER ON PORT D
    DEFINE LCD_RSBIT 2 'R/S ON PORTD.2
    DEFINE LCD_EREG PORTD 'E-CLOCK ON PORT D
    DEFINE LCD_EBIT 3 'E-CLOCK ON PORTD.3
    DEFINE LCD_BITS 4 'DATA BUS ONLY 4 BITS
    DEFINE LCD_LINES 2 'LCD DISPLAY LINES
    ' Declare Port Variables
    ' VAR PORTA.0 '1-ANALOG INPUT #0
    ' VAR PORTA.1 '1-ANALOG INPUT #1
    ' VAR PORTA.2 '1-ANALOG INPUT #2
    ' VAR PORTA.3 '1-ANALOG INPUT #3
    WATCH_DOG VAR PORTA.4 '0-RUN LED & WATCH DOG TOGGLE INPUT TO ADM690LAN
    ' VAR PORTA.5 '1-ANALOG INPUT #4
    BUSBAT VAR PORTB.0 '1-VDD OUTPUT FROM MCP-201
    BUSFALT VAR PORTB.1 '1-~FAULT OUTPUT FROM MCP-201
    ' VAR PORTB.2 '1-SPARE TO PIN 2 J-9
    ' VAR PORTB.3 '1-SPARE TO PIN 4 J-9
    CS_WAKE VAR PORTB.4 '0-CHIP SELECT/WAKE TO MCP-201
    ' VAR PORTB.5 '1-SPARE TO PIN 6 J-9
    RX2 VAR PORTB.6 '1--SECONDARY RS-232 RECEIVE LINE
    TX2 VAR PORTB.7 '0-SECONDARY RS-232 TRANSMIT LINE
    UCN_STB VAR PORTC.0 '0-UCN5832A DATA STROBE
    CCP2 VAR PORTC.1 '0-J-12 PIN 2 CCP2/PWM
    CCP1 VAR PORTC.2 '0-J-12 PIN 1 CCP1/PWM
    SCL VAR PORTC.3 '1-SCL-I2C (24LC128)
    SDA VAR PORTC.4 '0-SDA-I2C (24LC128)
    BUTT0 VAR PORTC.5 '1-ROTARY ENCODER BUTTON
    TX1 VAR PORTC.6 '0-PRIMARY RS-232 TRANSMIT LINE
    RX1 VAR PORTC.7 '1-PRIMARY RS-232 RECEIVE LINE
    A_IN VAR PORTD.0 '1-ROTARY ENCODER CHANNEL-A
    B_IN VAR PORTD.1 '1-ROTARY ENCODER CHANNEL-B
    REGSEL VAR PORTD.2 '0-REGISTER SELECT TO DISPLAY
    ECLK VAR PORTD.3 '0-"E" CLOCK TO DISPLAY
    DB4 VAR PORTD.4 '0-DATA BIT 4 TO DISPLAY
    DB5 VAR PORTD.5 '0-DATA BIT 5 TO DISPLAY
    DB6 VAR PORTD.6 '0-DATA BIT 6 TO DISPLAY
    DB7 VAR PORTD.7 '0-DATA BIT 7 TO DISPLAY
    CLOCK VAR PORTE.0 '0-CLOCK FOR DATA INPUT & OUTPUT TO 4014 & UCN5832A
    P_S_DATA VAR PORTE.1 '0-P/S INPUT TO 4014 & DATA INPUT TO UCN5832A
    DAT_IN VAR PORTE.2 '1-DATA INPUT FROM 4014
    ' Define Program Constants
    PULSE CON 5 'PULSE FOR STROBING LATCHES ~10uS.
    PARITY CON 8192 'PARITY EQUIV.
    INVERT CON 16384 'INVERT EQUIV.
    MSBFIRST CON 1 'ELIMINATE USING "MODEDEFS.BAS"
    MSBPRE CON 0 '""
    LSBPRE CON 1 '""
    MSBPOST CON 2 '""
    LSBPOST CON 3 '""
    BAUD CON 32 'BAUD RATE (19200) FOR EXTERNAL USE
    ADSTOR CON $F0 'A/D CALIBRATION STORAGE STARTING LOCATION (16 BYTES)
    MESSTABLE CON $7000 'MESSAGE LOOKUP TABLE ADDRESS IN PROGRAM FLASH MEMORY
    ' Declare Variables
    POINTER1 VAR WORD '""
    POINTER2 VAR WORD '""
    POINT2LO VAR POINTER2.LOWBYTE
    POINT2HI VAR POINTER2.HIGHBYTE
    ' DO NOT CHANGE THESE LINES
    TRISA = %101111 'INITIALIZE PORT DIRECTIONS
    TRISB = %01101111
    TRISC = %10101100
    TRISD = %00000011
    TRISE = %00000100
    OSCCON = 0 'SET SYSTEM CLOCK SWITCH BIT
    RCON = %00011111 'CLEAR IPEN,RI,TO,PD,POR,BOR
    INTCON2 = %11000000 'NO PULL-UPS,INTEDG0 RISING,INTEDG1,INTEDG2,TMR01P,RBIP
    INTCON3 = %00000000 'CLEAR INT2IP,INT1IP,INT2IE,INT1IE,INT2IF,INT1IF
    PIE1 = %00000000 'CLEAR ALL INTERRUPT ENABLE BITS
    PIE2 = %00000000 'CLEAR ALL INTERRUPT ENABLE BITS
    IPR1 = %00000000 'SET ALL INTERRUPT PRIORITY BITS TO LOW
    IPR2 = %00000000 'SET ALL INTERRUPT PRIORITY BITS TO LOW
    PIR1 = %00000000 'CLEAR ALL INTERRUPT FLAGS
    PIR2 = %00000000 'CLEAR ALL INTERRUPT FLAGS
    ADCON0 = %10000001 'FOSC/64,AN0,A/DONE,A/D OFF
    ADCON1 = %11000010 'RIGHT JUST,A/D CLOCK SELECT,RA0:RA3,RA5 ANALOG PINS, RE0:RE2 DIGITAL PINS
    LVDCON = %00001111 'CLEAR IRVST,LVDEN,AND SELECT LVDIN
    WDTCON = %00000000 'DISABLE WATCH DOG TIMER
    T0CON = %00000000 'PRESCALER,WRITE PRESCALER 1/2, TURN OFF TIMER 0
    T1CON = %10000100 'WRITE PRESCALER 1/1, TURN OFF TIMER 1
    T2CON = %00000100 'WRITE PRESCALER 1/1, TURN ON TIMER 2
    T3CON = %10000100 'WRITE PRESCALER 1/1, TURN OFF TIMER 3
    GOTO COLD
    '------------ INITIALIZATION OF HARDWARE AFTER RESET -----------------
    COLD:
    CLEAR
    TX1 = 1 'INITIALIZE SERIAL DATA TRANSMIT LINE (1ST)
    TX2 = 1 'INITIALIZE SERIAL DATA TRANSMIT LINE (2ND)
    REGSEL = 0 'SEY REGISTER SELECT FOR DISPLAY LOW
    ECLK = 0 'INITIALIZE E-CLOCK TO DISPLAY
    UCN_STB = 0 'INITIALIZE UCN5832A DATA STROBE LINE
    P_S_DATA = 0 'SET PARALLEL/SERIAL SELECT LINE TO 4014B
    CLOCK = 0 'INITIALIZE DATA CLOCK TO 4014B's & UCN5832A
    PutMulResult macro Const32
    MOVE?CB low Const32, R2
    MOVE?CB low (Const32 >> 8), R2 + 1
    MOVE?CB low (Const32 >> 16), R0
    MOVE?CB low (Const32 >> 24), R0 + 1
    'MAIN LOOP FOR PROGRAM
    LOOP:
    INTERRUPTBIT = INTCON.7 'SAVE STATUS OF INTERRUPT ENABLE BIT
    INTCON.7 = 0 'DISABLE ALL INTERRUPTS
    PULSIN CCP1,1,POINTER1 'MEASURE HIGH PULSE
    INTCON.7 = INTERRUPTBIT 'RE-ENABLE ALL INTERRUPTS
    IF POINTER1 > 0 THEN
    @ PutMulResult 15000000 ' Load PBP internal vars Max= 2,147,483,648
    POINTER2 = DIV32 POINTER1 ' Divide 15000000/(PERIOD/2)
    POINTER2 = 0
    LCDOUT $FE,$80,DEC5 POINTER2
    GOTO LOOP 'DO IT AGAIN and AGAIN and AGAIN
    Default Re: Computer Fan RPM Sensor Reading
    Hey Guys well i think that nice info about computer fan Rpm sensor.Thanks!!
    I'd like to control rotation of PC fan (whenever it is rotating or not), but do not want to constantly call PULSIN. Is there some way of timer/interrupt combo, to do this in background?
    Found a special chip from Microchip for exactly that task - TC670: http://www.farnell.com/datasheets/87877.pdf
    Maxim also has almost similar chip - MAX6684, which is a bit expensive, but much simpler to use and no programming required.
  1. Interrupt RPM and Taylors Elapsed time on 18F4620
    By Tobias in forum mel PIC BASIC Pro
    Last Post: - 3rd February 2010, 16:12
  2. Pulsin vs. Interrupt RPM measurement
    By Tobias in forum General
    Last Post: - 31st December 2009, 01:29
  3. RPM - DIV32 Problem
    By davewanna in forum mel PIC BASIC Pro
    Last Post: - 11th April 2008, 04:33
  4. Code Issue - select case or 'if' issue - not sure why
    By jamie_s in forum mel PIC BASIC Pro
    Last Post: - 7th October 2007, 08:52
  5. pc cooling fan rpm monitoring
    By Kamikaze47 in forum mel PIC BASIC Pro
    Last Post: - 5th December 2005, 23:08
