A/D problem on 18F2550 ?
Results 1 to 4 of 4
    Feb 2005
    Essex, UK
    I thought i have, the register that i thought was applicable was the ADCON1 which has been set to ADCON1 = %00001111.
    Are there any others that i am missing.
    I thought this was the only one, as if i set the code to:
        if Switch = 1 THEN
            gosub flash
    GOTO Main
    Flash:
        For loop = 1 to 10
            Redled = 1
            Pause 50
            Redled = 0
            Pause 50
        Next Loop
    When you push the button, it does jump to the Flash routine. So i am guessing it is in digital mode.
    I have a pull-down resistor on the input pin, which when the switch is pressed the input line goes to 5v.
    I'll keep trying for a solution. Of course it could be my code up the spout !!
    Tissy,
    Well, my original comment is still there, but I guess the thought behind it didn't make it through.
    ' use a pin with Schmitt Trigger input
  1. A/D converter problem
    By netstranger.nz in forum mel PIC BASIC Pro
    Last Post: - 13th September 2009, 08:56
  2. A/D conversion problem in 18F2520, 2523, 2550 etc.
    By selimkara in forum mel PIC BASIC Pro
    Last Post: - 10th March 2008, 17:26
  3. Array problem (18F2550)
    By Ronald123 in forum mel PIC BASIC Pro
    Last Post: - 8th January 2008, 19:47
  4. Problem with A port on 18F2550
    By NL2TTL in forum mel PIC BASIC Pro
    Last Post: - 9th May 2007, 23:59
  5. A/D conversion problem with pic16F88
    By Tapio Linkosalo in forum mel PIC BASIC Pro
    Last Post: - 18th August 2006, 12:42
