Writing to a table.
Results 1 to 5 of 5
    Italy
    I understand that with the PIC16F648 you control the
    configuration of the 7 Control channels of a radio control (R/C).
    For each of the 7 control channels you have the following parameters:
    - Servo Reversing (1 byte)
    - Variable Dual Rate (3 bytes)
    - Adjustable Travel Volume  (3 bytes)
    These parameters are stored in the EEPROM of the PIC.
    For each control channel you use 7 bytes of EEPROM.
    In total 49 bytes are used in the EEPROM.
    Store the values in the EEPROM as data blocks.
    Each block of data will contain the 7 bytes necessary
    to store the parameters of a channel. We will call
    these data blocks RECORDS. Below you can see the
    map of your EEPROM. The first 7 bytes (0-6) of the
    EEPROM are not used and are available for other uses.
    EEPROM map
    Where:
    X= Not used
    R= Servo Reversing (1 byte)
    DDD= Dual Rates (3 bytes)
    TTT= Travel Volume (3 bytes)
     REC 0  REC 1  REC 2  REC 3  REC 4  REC 5  REC 6  REC 7
     DUMMY  (CH1)  (CH2)  (CH3)  (CH4)  (CH5)  (CH6)  (CH7)
    _______-------_______-------_______-------_______-------
    XXXXXXXrdddtttRDDDTTTrdddtttRDDDTTTrdddtttRDDDTTTrdddttt
    01234567891111111111222222222233333333334444444444555555 (EE Address)
              0123456789012345678901234567890123456789012345
    To find out the record address for the selected channel:
    (You know the channel number because you have selected it on the LCD).
    record_address = channel_number * 7
    Once you have calculated the record address:
    (The address of the first byte of the record).
    To read the Servo Reversing byte from the EEPROM:
    READ record_address, servo_reversing
    To read the Dual Rate first byte from the EEPROM:
    READ record_address + 1, dual_rate_b1
    To read the Dual Rate second byte from the EEPROM:
    READ record_address + 2, dual_rate_b2
    To read the Dual Rate third byte from the EEPROM:
    READ record_address + 3, dual_rate_b3
    To read the Travel Volume first byte from the EEPROM:
    READ record_address + 4, travel_volume_b1
    To read the Travel Volume second byte from the EEPROM:
    READ record_address + 5, travel_volume_b2
    To read the Travel Volume third byte from the EEPROM:
    READ record_address + 6, travel_volume_b3
    Below are the variables in RAM.
    These variables are used as temporary storage and their
    content will change based on the selected channel number.
    channel_number
    record_address
    servo_reversing
    dual_rate_b1
    dual_rate_b2
    dual_rate_b3
    travel_volume_b1
    travel_volume_b2
    travel_volume_b3
    Do the same to WRITE to the EEPROM.
    Best regards,
    Luciano
    Rhatidbwoy's Avatar
    Rhatidbwoy Guest
    took a little time to come with it huh. I like it. I will have to sit down and look at it several time to learn what you did. I can say that I understand and follow it, but to truly I learn something, I will have to sit and read. Thanks man.
  1. Origin of Assembly Table
    By dksoba in forum mel PIC BASIC Pro
    Last Post: - 8th February 2010, 20:34
  2. Lookup Table
    By yasser hassani in forum mel PIC BASIC Pro
    Last Post: - 11th March 2008, 11:38
  3. PICBasic newbie problem
    Last Post: - 12th February 2008, 01:55
  4. PIC 18F452 Table Pointer/ Table Read
    By sougata in forum mel PIC BASIC Pro
    Last Post: - 14th March 2006, 04:07
  5. Message String Table using Readcode
    By mytekcontrols in forum Code Examples
    Last Post: - 11th July 2005, 00:17
