int to string conversion
Results 1 to 4 of 4
    Default int to string conversion
    How to convert from int to string. I wanna to display number in LCD because LCD accept on string. TQ
    Dec 2003
    Wichita KS
    One way is th "Dig" command, you can isolate each digit of your number, and output it to your LCD.
    Dwayne
    Ability to Fly:
    Pilots that are Flying:
    If I underastand your question correct what you need is the # operator.
    LCDOUT $FE, 1, #YourVariable
    If YourVariable holds the value 106 this command will print 106 on the LCD instead of the ASCII representation of 106 which is "j". This will also work with Serout, Serout2, Hserout & Debug.
    /Henrik Olsson.
    Thanks HenrikOlsson, your reply is very helpful.
  1. How about String Variables?
    By mytekcontrols in forum PBP Wish List
    Last Post: - 20th January 2015, 12:53
  2. String Conversion
    By bethr in forum mel PIC BASIC Pro
    Last Post: - 19th August 2009, 19:57
  3. help: TMR0 interrupts disabling PORTAchange interrupts???
    Last Post: - 19th August 2008, 15:10
  4. Embedded Strings in your Code Space
    By mytekcontrols in forum mel PIC BASIC Pro
    Last Post: - 9th March 2008, 07:50
  5. Visual Basic 6 & Access 2000
    By Demon in forum Off Topic
    Last Post: - 7th September 2006, 04:39
