Macro Error
Results 1 to 8 of 8
Thread: Macro Error
    Dec 2004
    nebraska
    Default Macro Error
    Hi
    I tried to use HPWM command and this error came up.
    error:macro HPWM?tcc not found im macro file.
    Do I have a corrupt file or what I'm using a 18F458. I've never had problems with any other commands before here is my code.
    Define OSC 20 'OSC (20Mhz)
    Include "modedefs.bas" 'Includes Definitions.
    INTCON = %00000000 'Turns off all Interrupts.
    ADCON0.0 = 1 'Turns off A/D Module
    ADCON1 = 6 'Turns PortA and PortE to Digital Pins
    'Defines wait time for PulsIn.
    TrisB.1 = 0
    Define Loader_USED 1
    HPWM PortD.7,127,5600
    PortB.1 = 1
    Pause 1000
    PortB.1 = 0
    Pause 1000
    Goto Main
    Am I missing a define or an include. I thought maybe I got a virus or something that screwed of a file so I reloaded PBP 2.44 and had the same problem.
    please help
    thanks
    Hi Shawn,
    Oh, if only you could do that, it would make things so much easier.
    But you can't assign the PIN for the HPWM command. The CCP module is hard wired to pin 17 (RC2) on the 458. So you need to supply the channel number, which in this case is 1.
    HPWM 1,127,5600
    And, since you're turning off all the A/D inputs, don't forget about the comparators on PORTD
    CMCON = 7
    Dec 2004
    nebraska
    Hi Darrel
    The reason I used PortD.7 was because the data sheet said the pic18F458 has five PWM pins and Portd.7 is one of them.
    So anyway what does the one stand for in HPWM 1,127,5600. I assumed it stood for a pin but I put an 8 in place of the one and the file still assembled in microcode studios.
    What im doing with this is I need to PWM channels running at the same time.
    I'm running 2 PWM motors from a kit I got. HPWM command I hope will work since the frequenct will stay the same but not the duty cyle. What else can I do.
    The 18F458 only has 2 CCP modules. One is a normal CCP, and the other is an Enhanced CCP or ECCP.
    The ECCP does have several outputs, and can be used for controling other types of motors, but it won't give you that many PWM outputs, and you can't choose which pin to use.
    You can still use it like a normal CCP, but the output will be on RD4.
    HPWM 2,127,5600
    So, 1 selects the CCP and 2 selects the ECCP.
    Oh yeah, forgot to mention that you need to add these lines to the bottom of the 18F458.INC file in your PBP folder.
    CCPR2H  = ECCPR1H
    CCPR2L  = ECCPR1L
    CCP2CON = ECCP1CON
    Dec 2004
    nebraska
    Darrel
    ThankYou for your help it has been awhile since I've been able to work on my projects.
    Shawn
  1. PBPro error "Macro USBINIT? not found in macro file"
    By Bonxy in forum mel PIC BASIC Pro
    Last Post: - 4th October 2011, 10:06
  2. Replies: 6
    Last Post: - 4th November 2009, 14:36
  4. Optimizing DIV
    Last Post: - 22nd September 2008, 05:58
  5. 16F88 Compile error
    By Toley00 in forum mel PIC BASIC Pro
    Last Post: - 2nd November 2005, 01:22
