Instant interrupts in Basic?
Results 1 to 2 of 2
    Bulman's Avatar
    Bulman Guest
    Default Instant interrupts in Basic?
    Hi.
    How do you write your instant interrupts? When the desired code for the interrupt is too complex to write in ASM, I've to write in Basic. But I dont like the software /pseudo/ interrupts.
    Bulman, First you need to locate the instant interrupt routines written by Tim Box and then place these lines before any other lines in your code:
    INCLUDE "INT_CTRL-18F.inc" ' Interrupt Control routines
    DEFINE TMR1_FREQ 100
    DEFINE TMR1_HANDLER _TIMR1
    Then before your main code segment, insert the interrupt routine's. Here is an example of a simple one using a 100 Hz. interrupt to set some pacing counters.
    'INTERRUPT SERVICE ROUTINE FOR TIMER 1
    TIMR1:
    LOOPCNTR = LOOPCNTR + 1 'INCREMENT LOOP COUNTER
    TIMSTAMP = TIMSTAMP + 1 'INCREMENT VARIABLE
    VOTIME = VOTIME + 1 'INCREMENT VARIABLE
    LEDTIMR = LEDTIMR + 1
    IF LEDTIMR >= 10 THEN
    TOGGLE WATCH_DOG 'KEEP WATCHDOG HAPPY
    LEDTIMR = 0
    After the interrupt routine is complete you mearly "Return" to the program. It's that simple. All if the information is in the "Instant Interrupt Routine" documentation.
    I can't remember where I found the "Instant Interrupt Routine" include file but if you do a search of the web I'm sure you will find it. LOL
  1. Instant Interrupts - Revisited
    Last Post: - 17th February 2016, 23:14
  2. Clock using Instant Interrupts
    By PICpocket in forum mel PIC BASIC Pro
    Last Post: - 16th February 2009, 22:43
  4. DT instant interrupts with mister_e keypad
    Last Post: - 26th November 2008, 21:02
  5. DT's Instant Interrupts trouble
    Last Post: - 24th November 2008, 21:48
