Need setting to turn off 16F688 comparators
Results 1 to 2 of 2
    Thomas Williams's Avatar
    Thomas Williams Guest
    Smile Need setting to turn off 16F688 comparators
    I am in need of some help to determine the correct setting to turn the comparators off on a 16F688 so that I can use them for A/D inputs.
    so far:
    cmcon0= %00000000
    cmcon1= %00000011
    VRCON = %00000000
    any other suggestions?
    jessey's Avatar
    jessey Guest
    Hello Thomas,
    I just bought 30 16f688's at a very low price so I've been looking for all the information I could find about them and as far as what I've found from reading the archives here is that this statement also works CMCON0 = 7 ' Comparators disabled.
    I don't quite understand the data sheet but it says:
    Note:
    The ANSEL (91h) and CMCON0 (19h)
    registers must be initialized to configure
    an analog channel as a digital input. Pins
    configured as analog inputs will read ‘0’.
    Then it goes on to say bit 7-6: Unimplemented: Read as '0'. Does that mean that setting CMCON0 to either 6 or 7 has the same effect?
    jessey
  1. PICKit2 - warning about configuration words
    Last Post: - 4th August 2009, 14:01
  2. DS1820 with 16f688
    Last Post: - 23rd May 2009, 05:07
  3. new and need help
    By smeghead in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2008, 20:19
  4. LCD will not start
  5. Need help to shut off comparators for 16f688
    Last Post: - 30th October 2006, 04:54
