Lcd 16f877a Heeeeelp!!!
Results 1 to 3 of 3
    Dec 2005
    Default Lcd 16f877a Heeeeelp!!!
    HI ALL, THIS CODE NOT WORK ON 16F877A. WHY?
    I HAVE DEFINE NEW REGISTRY.
    THX
    'set lCD data port
    define LCD_DREG PORTB
    'set starting data bit(0 or 4) if 4-bit bus
    DEFINE LCD_DBIT 4
    'set LCD register select port
    DEFINE LCD_RSREG PORTB
    'set LCD register select bit
    DEFINE LCD_RSBIT 1
    'set LCD enable port
    DEFINE LCD_EREG PORTB
    'set LCD enable bit
    DEFINE LCD_EBIT 2
    'set LCD bus size (4 or 8 bits)
    DEFINE LCD_BITS 4
    'set number of lines on LCD
    DEFINE LCD_LINES 2
    'set command delay time in us
    DEFINE LCD_COMMANDUS 2000
    'set data delay time in us
    DEFINE LCD_DATAUS 50
    loop:
    Pause 500
    LCDOUT $FE,1
    LCDOUT "test LCD"
    LCDOUT $FE,$C0
    LCDOUT "16F877A"
    goto loop
    Mentor, Ohio
    Smile
    Hi Chip,
    Try this:
    loop:
    Pause 500
    LCDOUT $FE,$80,"test LCD Line 1"
    LCDOUT $FE,$C0,"16F877A Line 2"
    goto loop
    What you want displayed on a line should go directly after the command.
    BobK
    Dec 2005
    Default Ok
    THX BobK.
    BY
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 19:14
  3. LCD will not start
  4. Need cheap i2c LCD for 16F877a
    By CodeShredder in forum mel PIC BASIC Pro
    Last Post: - 6th December 2006, 01:25
  5. Dedicated LCD Controller question
    By chuckles in forum mel PIC BASIC Pro
    Last Post: - 27th February 2006, 14:44
