Timed pulses on 2 pins
Results 1 to 2 of 2
    Danie Joubert's Avatar
    Danie Joubert Guest
    Question Timed pulses on 2 pins
    Hallo group
    As a new comer to the PBP family I first like to say thanks to all for the tons of info available.
    I have a problem in writing code to check two input pins for changing pulses. The pulses from a shaft arive at the two pins at varying speed and is are alway 90 degrees apart. I want to use the pulses to determine whether the shaft is turning forward or backword.
    Is there anyone who has done something like this?
    If so will you please be so kind in helping.
    I have just cross-graded from the first edition of Pb to PBP, great exitment !!
    Thanks group
    Let’s call our inputs SensorA and SensorB. SensorB is 90 degrees away from SensorA.
    Rotating in one direction, SensorA pulses first, followed by SensorB 90 degrees later, then followed by SensorA again 270 degrees after that.
    Rotating in the other direction, SensorA pulses, followed by SensorB 270 degrees later, then followed by SensorA again 90 degrees after that.
    You will see from this that there are two distinct Timing periods, a short 90 degree period, and a long 270 degree period. Let’s call this TimeShort and TimeLong.
    If SensorB pulse is followed by TimeLong, the we are rotating in one direction. If SensorB pulse is followed by TimeShort you are rotating in the other direction (you can just as easily use SensorA rather than SensorB here).
    Simply start a Timer on one Pulse, save the value on the next pulse, restarting the count. After two Timed counts you can then determine the direction of rotation (and as a bonus, the timed counts themselves will give you the rotational speed). It is probably best to junk the first Pulse from start-up/power-on since you don't know where your shaft is at rest.
    Melanie
  1. How to drive the Vinculum VDIP1 in UART mode
    By BrianT in forum Code Examples
    Last Post: - 23rd May 2013, 13:34
  2. USB-FTDI[UM232R] with PIC16f877a
    By bjox in forum USB
    Last Post: - 23rd February 2008, 23:40
  3. Microcontroller with 2 way paging application problem
  4. Timing input pulses and re-outputting them
    Last Post: - 28th February 2007, 02:50
  5. interfacing SPI with 2 pins?
    By modifyit in forum mel PIC BASIC Pro
    Last Post: - 1st December 2005, 23:04
