How to code Baud 38400
Results 1 to 3 of 3
    May 2005
    Angry How to code Baud 38400
    I try to conect PIC to PC with Max232 we need to connect at 38400 baud rate
    microcode studio ,PBP 2.45
    PIC?
    OSC speed?
    Did you read the PBP manual in SEROUT, DEBUG,SEROUT2, HSEROUT section?
    Sep 2005
    Campbell, CA
    I don't know if PBP has a DEFINE that goes that high, but in any case you can always directly set the SPBRG register. The exact setting depends on your oscillator frequency, but if you are running at 20Mhz, you can set
    SPBRG = 32 to give you 38.4Kbaud.
    You will have to consult the datasheet if you are running at a different frequency.
    Charles Linquist
    Last Post: - 8th March 2010, 21:58
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  3. Can't set 38400 baud @ 48Mhz
    By b1arrk5 in forum Serial
    Last Post: - 20th January 2009, 00:56
  4. Loop with two motor and 2 sensors
  5. Auto Baud Rate Detection
    By mytekcontrols in forum Serial
    Last Post: - 31st October 2005, 03:17
