having problems with Hantronix 20x4 lcd
Results 1 to 17 of 17
Threaded View
  1. #2
    Italy
    Could be a timing problem. Write a program to verify your configuration settings.
    With the code below you should see the light of the LED 60 times in 1 minute.
    Just count and check your watch. (The LED is ON for 500 ms and OFF for 500 ms).
    Best regards,
    Luciano
            Low PORTB.0    ' Turn off LED connected to PORTB.0
    loop:   Toggle PORTB.0  ' Toggle the LED connected to PORTB.0
            Pause 500       ' Delay for 500 milliseconds
            Goto loop       ' Go back to loop and blink LED forever
    (Connection schematic, see the LED and the 470 ohm resistor)
  1. 16f688 LCD what have I done wrong
    Last Post: - 8th August 2009, 20:54
  2. Pic18f452 with 20x4 LCD Help
    By djmachine in forum mel PIC BASIC Pro
    Last Post: - 6th November 2008, 23:43
  3. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  5. LCD 20X4 connect with DS1820
    By jojokatada in forum mel PIC BASIC Pro
    Last Post: - 9th March 2005, 12:04
