LCD Controller Questions
Results 1 to 2 of 2
    Question LCD Controller Questions
    I understand PBP supports parallel LCD's that use the Hitachi HD44780U controllers. Does this also include the clones : Samsung KS0066U, Sitronix ST7066, and the Sunplus SPLC780A1 used in the Hantronix displays? If so I assume the code will be the same with no variations necessary? Are the serial displays using the same basic controllers and adding the RS-232 interface? Just now getting into this part of the micro C experience and trying to avoid the pitfalls.
    If it's a 'clone' then it should work - otherwise it wouldn't be a 'clone' would it?
    Yes, Serial LCD displays are little more than an LCD with (usually) a microprocessor accepting a two-wire Serial Input (Ground & Data) and outputting everything it receives straight to a conventionally connected parallel LCD.
  1. LCD with T6963C controller
    By Demon in forum Off Topic
    Last Post: - 22nd May 2022, 21:11
  2. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  3. Need help with LCD number display.
  4. LCD will not start
  5. Dedicated LCD Controller question
    By chuckles in forum mel PIC BASIC Pro
    Last Post: - 27th February 2006, 15:44
