computer controlled car
Results 1 to 10 of 10
    Dec 2005
    Lightbulb computer controlled car
    in fact a vb code sends 4 bytes for controlling the for direction of the car!
    the byte goes out from the serial port of the pc and goes into the PIC through A0.
    then this byte should be outputed on port b of the pic(b0...b7)!
    the algorithm is as follows: the pic receives the byte bit by bit through A0.
    it stores the byte in a register and then output it on port B
    the problem is teh code! can anyone help?
    Italy
    From the PicBasic Manual "SERIN"
    While single-chip RS-232 level converters are common and
    inexpensive, the excellent I/O specifications of the PICmicro
    MCU allow most applications to run without level converters.
    Rather, inverted input (N300..N9600) can be used is conjunction
    with a current limiting resistor.
    Q1: Are you using a RS-232 level converter like the chip
    MAX232 (RS232>TTL & TTL>RS232) or just a current limiting resistor?
    Q2: What is the used baud rate? (1200, 2400, 9600)
    Best regards,
    Luciano
    Example of circuit using a MAX232:
    Dec 2005
    Lightbulb compter controlled car!
    yea i m using the max232 chip and i m using the 9600 baud rate!
    the serin can be modified for my purpose but i need how?
    Italy
    5.68. SERIN
    SERIN
    Pin,Mode,{Timeout,Label,}{[Qual...],}{Item...}
    Receive one or more Items on Pin in standard asynchronous format
    using 8 data bits, no parity and one stop bit (8N1). SERIN is similar to
    the BS1 Serin command with the addition of a Timeout. Pin is
    automatically made an input. Pin may be a constant, 0 - 15, or a
    variable that contains a number 0 - 15 (e.g. B0) or a pin name (e.g.
    PORTA.0).
    With the SERIN command you can receive one or more Items.
    Declare four variables for your four bytes. These four
    variables will be the "Items" of the SERIN command.
    Read the PicBasic Pro manual, search this forum.
    If you need help, post your code and the members of this
    forum will help you to fix your code.
    Best regards,
    Luciano
    Quote Originally Posted by elios115
    the algorithm is as follows: the pic receives the byte bit by bit through A0. it stores the byte in a register and then output it on port B
    Maybe something like this?
    SERIN 1,N2400,[“A”],B0 'Wait until the character “A” is received serially
    'on Pin1 and put next character into B0
    portb=B0
    This is on the manual, page 99.
  1. Car radio (Car radio and electronics support forum)
    By freewillover in forum Forum Requests
    Last Post: - 1st July 2009, 20:41
  2. Getting rid of noise of car battery/alternator
    By passion1 in forum mel PIC BASIC Pro
    Last Post: - 9th March 2008, 06:11
  3. Slot Car timer with pic 16f84a
    By Snap in forum Serial
    Last Post: - 5th July 2007, 05:58
  4. Need help with RC car code
    By rey1867 in forum mel PIC BASIC Pro
    Last Post: - 7th June 2006, 01:18
  5. Remote Car Starter Safety
    By CocaColaKid in forum General
    Last Post: - 22nd November 2005, 10:10
