Hi PaulBarter,
I've just completed a data logging project with the USB Wiz, a device that has both Alfat and USB on it. It appears from your description that the communications is about the same for both the USB Wiz and stand alone Alfat. Here are some things I discovered:
Your are correct in holding CTS low, it must be low or the alfat will not send data (I just tied mine to ground)
You can ignore RTS and leave it disconnected or as an input as you desire. If you intend to talk to Alfat at very high speeds with lots of data you may have to use both CTS and RTS to supervise data transfers. I run my interface at 9600 and neither are needed.
Alfat Reset should be HIGH at all times except when you are doing a reset. You make it an input so that means it floats and *may* be causing part of your communications problems. If you are going to reset the alfat with different devices and need to float your PIC input then a pull up resistor will be needed on the Reset line. Otherwise just place a HIGH alfat_Reset statement early on in your program. I do a reset on mine by Pulsout Alfat_Reset 1 after having pulled it high with a High Reset_alfat statement.
However, I suspect your major communication problem is this: Alfat_RX needs to be held HIGH. You can do this with a pull up resistor or as I did by putting a High Alfat_RX statement in my program BEFORE doing an Alfat reset. This line is very sensitive to noise and *will* cause error after error if not strongly held either by the PIC driving it high or a pullup resistor.
On the USB Wiz there is an additional signal to contend with. It is one called Mode 0. It must be grounded to hold the USB Wiz in RS232 mode. I don't know if Alfat has the same issue.
I'm not associated with the Alfat people and probably can't suggest much more than this but thought I could give you the benefit of my findings.
TomE
