Alfat Sd/mmc
Results 1 to 32 of 32
Thread: Alfat Sd/mmc
    Sep 2003
    Vermont
    Quote Originally Posted by eoasap
    serin2 ALFAT_TX,84,bufchar]
    there should be a '[' before bufchar, right?
    do i need to declare bufchar as a byte ?
    Is there a loop for the serin2 alfat_tx,84, [bufchar] ?
    How do i use datardy?
    I was getting errors using 'read:' also, so changed it to read1:
    Sorry, I was doing it from memory. "READ" is a reserved word. My bad. DATARDY is a pin on Alfat. If it is high, then Alfat has data to send. It takes about ten microseconds to change states if it is empty, or transitions high. It is a flag and should be aliased as a bit variable, just as ALFAT_BUSY should.
    Ron
    eoasap's Avatar
    eoasap Guest
    is the rest of it right? because i still can't quite get it.
    Sep 2003
    Vermont
    It works for me. Any output from Alfat at all?
    eoasap's Avatar
    eoasap Guest
    what i'm doing is declaring bufchar as a byte, and then loop at the end of
    read:
    serin2 ALFAT_TX,84,[bufchar]
    lcdout bufchar
    goto read
    like that, i get a bunch of gibberish. yesterday i was getting numbers like 292 (clears screen) 302 (clears screen) 306 (clears screen) .... etc
    Sep 2003
    Vermont
    read:
    lcdout bufchar
    goto read
    When I get to my lab, I will send you a snippet of code. bufchar is a byte variable. It can't go over 255, so there must be a couple of variables in there.
    eoasap's Avatar
    eoasap Guest
    Thanks Ron, i'm sure there's just something minor i'm leaving out (hopefully!) you've already been such a big help! thanks
    PaulBarter's Avatar
    PaulBarter Guest
    Did you ever get this sorted? I'm about to embark on a very similar exercise with a 16F877 and alfatSD board using PBP. Any snippets of code or other advice would be greatly appreciated. TIA
  1. Where should I discuss SD/MMC FAT issues?
    By JD123 in forum General
    Last Post: - 2nd April 2008, 22:41
  2. pic + alfat sd
    By ranaz in forum General
    Last Post: - 27th July 2006, 07:08
  3. SD/MMC Adapter
    By lester in forum Adverts
    Last Post: - 11th July 2006, 16:47
  4. Reading and Writing from SD/MMC cards as FAT filesystem?
    By charliez in forum mel PIC BASIC Pro
    Last Post: - 22nd June 2006, 23:26
  5. GHI Electronics ALFAT and USBWiz products.
    Last Post: - 15th June 2005, 13:59
