Alfat Sd/mmc
Results 1 to 32 of 32
Thread: Alfat Sd/mmc
    Sep 2003
    Vermont
    Quote Originally Posted by eoasap
    has anyone here had any experience using this chip? i would like to do standard USART communications with it, and would like to hear what anyone says about it. thanks!
    I am using the Alfat SD board. It works fine in text mode, and SPI mode. Framed mode is a bit tricky, but easier to work with for parsing the data. What is your app? I have logged about thirty hours working with the board and have encountered every stupid thing my feeble code writing brain could come up with.
    Ron
    eoasap's Avatar
    eoasap Guest
    Ron,
    i will be reading in GPS sentances (USART), either parsing or selecting sentances, and outputting this directly to the SD card (also USART) in text mode as i think that would be the easiest way. did you code yours with picbasic? on alfats site they only have proton basic and assembly code and ovbiously want to use picbasic.
    Glenn
    Sep 2003
    Vermont
    Ron,
    Glenn
    I wrote everything in PBP. Text mode is the easiest and speed should no be an issue. I would suggest a PIC with a large amount of memory, such as the 18F2620, or an external EEPROM as intermediate storage. THe Alfat is a gas hog, so if you are using batteries, you are not draining 80 mils on a constant basis. I write 3K of data to the PIC then dump it into the Alfat in short bursts.
    Ron
    eoasap's Avatar
    eoasap Guest
    Ron, i'm using the 18LF8722 so memory shouldn't be much of a problem. do you think you could help me get started? as i'm a little overwhelmed by it all. I know i need to try simple stuff first, like creating a file, writing a bytes to it, and then verifying it on the computer, but i really am not sure how to get started with it.
    Glenn
    Sep 2003
    Vermont
    #1.Are you using the chip, or the SD board?
    #2. Have you had experience with the hardware USART?
    #3. Do you know what version of Alfat firmware is on the chip?
    #4. What are you using for a display? LCD/Debug/ICSD?
    For test purposes, I would suggest plain old Serin2/ serout2.The USART just adds one level of mystery. The device comes up at 9600 baud. No need for a 232 converter, if you are using a PIC, only with a PC in hyper term.
    I've got some routines, just let me know the above answers. Also, check the user's forum at GHIELECTRONICS.com
    eoasap's Avatar
    eoasap Guest
    The chip
    no experience
    no, but i think its 3.06
    LCD
    ok, i'll work on trying to learn the serin2/serout2. so i'll need to setup the code @9600 baud. is serin/serout hard to implement?
    Sep 2003
    Vermont
    My first suggestion is to buy the Alfat SD board with SD socket. It will be easier to work out the necessary code and limit the possible problems. Soldering that chip will be a major pain in the neck. I have ruined more than one until I discovered solder paste and toaster ovens.
    Either way, if you limit your possible sources of trouble, you will be able to concentrate on the interface. The absolute best purchase would be the Alfat development board. I was too cheap to buy one, and paid for it in the form of an extended learning curve.
    Rpn
  1. Where should I discuss SD/MMC FAT issues?
    By JD123 in forum General
    Last Post: - 2nd April 2008, 22:41
  2. pic + alfat sd
    By ranaz in forum General
    Last Post: - 27th July 2006, 07:08
  3. SD/MMC Adapter
    By lester in forum Adverts
    Last Post: - 11th July 2006, 16:47
  4. Reading and Writing from SD/MMC cards as FAT filesystem?
    By charliez in forum mel PIC BASIC Pro
    Last Post: - 22nd June 2006, 23:26
  5. GHI Electronics ALFAT and USBWiz products.
    Last Post: - 15th June 2005, 13:59
