How can I call Bootloader from Basic programm?
Results 1 to 4 of 4
    Jun 2005
    Default How can I call Bootloader from Basic programm?
    I need to pass control to Bootloader(Shipped with MCLoader) from running basic program. I tryed the following: @ goto 0, - the basic program performed restart, but not to the Bootloader. What are the right conditions( jump address, flags, etc.)?
    Thanks in advance.
    Jun 2005
    OK now I solved it.
    You should wait for null character(s) in serial stream (byte $00) and then execute the following code:
    MOVLW 0x1F
    MOVWF PCLATH
    GOTO 0x70D
    or simple @ GOTO 0 if you test it in the first 2K code segment.
    The whole example:
    DEFINE LOADER_USED 1 ' uses a bootloader
    define OSC 20
    DEFINE HSER_BAUD 115200
    Char var byte
    TXSTA.2=1
    SPBRG=10
    hserout ["Program Starting...",CR]
    ProgramStart:
    WHILE 1
    CHAR=1
    hserin 1,TIMEOUT,[Char]
    Timeout:
    IF CHAR=0 THEN
    MOVLW 0x1F
    MOVWF PCLATH
    GOTO 0x70D
    ' @ GOTO 0 'if this code is in the 1st 2k segment
    WEND
    micro's Avatar
    micro Guest
    excuse me for this equestion because im still newbie
    what does Bootloader mean?? and what does that for??
    thanks
    Jun 2005
    Quote Originally Posted by micro
    thanks
    Take a look here please:
    http://www.mecanique.co.uk/products/...ootloader.html
  1. 16F628A - Stops if release power switch.
    By dene12 in forum General
    Last Post: - 14th February 2009, 08:57
  2. Loop with two motor and 2 sensors
  3. PIC16F877 I2C programme
    By cooqo in forum mel PIC BASIC
    Last Post: - 21st April 2008, 11:02
  4. frequency meter in PBP
    Last Post: - 13th June 2007, 07:34
  5. Can I do this???
    By noobie in forum mel PIC BASIC
    Last Post: - 10th June 2006, 19:57
