floppy-emulator
Results 1 to 10 of 10
Thread: floppy-emulator
    Hangover, Germany
    Mööp...
    This computers don't have any PCI-Ports or any other useable ports...
    They are using DOS
    Italy
    Does it boot from an internal hard disk or from the floppy disk?
    If it boots from the floppy, do you have a 40 pin IDE connector on the motherboard?
    CPU version? (386, 486, Pentium).
    Best regards,
    Luciano
    Hangover, Germany
    Hello,
    I think there are very old prozessors,
    there is no HD, USB ...
    Italy
    If you have a IDE Standard 40 pin connector on the motherboard you can use that:
    http://www.acscontrol.com/Index_ACS....CF_Adapter.htm
    http://www.acscontrol.com/pdf/Produc...F-IDEToCFA.pdf
    From ACS IDE to CF Adapter User s Manual:
    http://www.acscontrol.com/pdf/Produc...ers_Manual.pdf
    Compact Flash cards use Flash Memory. Flash Memory has a limited number of Erase/Write cycles
    ~300,000. The controller in the Compact Flash card does wear leveling by spreading out the writes
    amongst various 'sectors' in the card to prevent premature wearout of a sector.
    Here's a link to the originator of the CF card that discusses how they 'wear level' the flash memory to
    optimize card life: http://www.sandisk.com/pdf/oem/WPaperWearLevelv1.0.pdf
    Digital cameras write to Compact Flash cards to store their photos. However, if you were to place a
    pagefile or swapfile on the Compact Flash card, the intense write activity would very quickly exhaust the
    life of the card.
    Best regards,
    Luciano
  1. USB keyboard emulator
    By Toley00 in forum USB
    Last Post: - 23rd January 2012, 00:57
  2. USB to rs232 emulator
    By Pic2008 in forum USB
    Last Post: - 5th March 2010, 15:54
  3. MPLAB ICE 2000 emulator pod
    By Wayne in forum Adverts
    Last Post: - 1st April 2009, 00:25
  4. terminal emulator with autoanswer
    By RFsolution in forum General
    Last Post: - 28th February 2008, 12:09
  5. PS2 keyboard emulator
    By robertg in forum mel PIC BASIC Pro
    Last Post: - 5th July 2007, 20:40
