floppy-emulator
Results 1 to 10 of 10
Thread: floppy-emulator
    Hangover, Germany
    Default floppy-emulator
    Hello,
    I want to build a floppy-emulator in order to throw away the floppys and the drives because of hardware-failures and to use SD-cards or so.
    Has anybody realized such interfaces ?
    PBP 2.50C, MCS+ 3.0.0.5, MPLAB 8, MPASM 5.14, ASIX Presto, PoScope, mE mikroBasic V7.2, PICKIT2
    Aug 2005
    Denver
    Default Emulator?
    If you're using XP, all you would need would be a $25 USB card adapter. The cards show up as additional drives on your PC. Just drag the data over from the floppy and throw your A Drive out the window.
    Italy
    Teac Floppy specifications:
    http://www.teac.de/dspd/downloads/da...fd05hf8630.pdf
    You are going to spend lots of time to achieve that.
    By the time you complete this project, the motherboard
    manufacturers will have removed the floppy disk controller
    from the motherboards!
    Good luck!
    Luciano
    Hangover, Germany
    Mööp...
    This computers don't have any PCI-Ports or any other useable ports...
    They are using DOS
    Italy
    Does it boot from an internal hard disk or from the floppy disk?
    If it boots from the floppy, do you have a 40 pin IDE connector on the motherboard?
    CPU version? (386, 486, Pentium).
    Best regards,
    Luciano
    Hangover, Germany
    Hello,
    I think there are very old prozessors,
    there is no HD, USB ...
    Italy
    If you have a IDE Standard 40 pin connector on the motherboard you can use that:
    http://www.acscontrol.com/Index_ACS....CF_Adapter.htm
    http://www.acscontrol.com/pdf/Produc...F-IDEToCFA.pdf
    From ACS IDE to CF Adapter User s Manual:
    http://www.acscontrol.com/pdf/Produc...ers_Manual.pdf
    Compact Flash cards use Flash Memory. Flash Memory has a limited number of Erase/Write cycles
    ~300,000. The controller in the Compact Flash card does wear leveling by spreading out the writes
    amongst various 'sectors' in the card to prevent premature wearout of a sector.
    Here's a link to the originator of the CF card that discusses how they 'wear level' the flash memory to
    optimize card life: http://www.sandisk.com/pdf/oem/WPaperWearLevelv1.0.pdf
    Digital cameras write to Compact Flash cards to store their photos. However, if you were to place a
    pagefile or swapfile on the Compact Flash card, the intense write activity would very quickly exhaust the
    life of the card.
    Best regards,
    Luciano
    Mar 2013
    Default Re: floppy-emulator
    [email protected]
    i can sell preprogrammed 16F1938 pic microprotsessor.
    You can buy them on eBay for $30 up, they sell them to replace floppys on cnc machines, and work with DOS. I put one in my FADAL, only after that did I realize I didn't know how to access the floppy on it LOL. I was able to access the files from dos though while testing it on a PC
    EDIT: They access flash drives not SD
    Mar 2013
    I not have opening inside those ebay type emulators,how many stuff they having inside ?, but this one here is as possible simply, and less of components means also less of price too. Even ahelet type floppy emulator can work wiht no segment and no buttons connected, just one sc card becomes one floppy. Same code, nothing needed change, you can easy make it reduced way if you need only one floppy in one sd card.
  1. USB keyboard emulator
    By Toley00 in forum USB
    Last Post: - 23rd January 2012, 01:57
  2. USB to rs232 emulator
    By Pic2008 in forum USB
    Last Post: - 5th March 2010, 16:54
  3. MPLAB ICE 2000 emulator pod
    By Wayne in forum Adverts
    Last Post: - 1st April 2009, 01:25
  4. terminal emulator with autoanswer
    By RFsolution in forum General
    Last Post: - 28th February 2008, 13:09
  5. PS2 keyboard emulator
    By robertg in forum mel PIC BASIC Pro
    Last Post: - 5th July 2007, 21:40
