Simple Question
Results 1 to 9 of 9
Thread: Simple Question
    koossa, Yes you will, This is the proven circuit used by many of us and it will also allow you to connect other equipment at a later time. Good luck...
    Dave Purola.
    Thank you DAVE!!!
    Is the Polarity of the 1uF capacitor on Pin 6 of the Max232 the correct way arround?
    Feb 2003
    Yes.
    Its the smoothing capacitor for VEE the internally generated NEGATIVE supply voltage
    Keith
    www.diyha.co.uk
    www.kat5.tv
    I upload the HEX file (16F877_04.hex) to my PIC using the Picstart plus, I have changed the settings in MPLAB as follow:
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=656&stc=1&d=1134568334 ">
    Is this correct?
    Please help!!
    I have changed my Schematic to look exactly like the one below and have uploaded the 16F877_04.hex with Picstart plus and MPLAB, then in Microcode studio plus I select Microcode Loader as my Programmer and changed the "ICD Serial Port" dropdown to COM2. From the menu I have then select "Project","Compile and Program".
    It then pops up with a dialog box "Reset Required, Please reset the target microcontoller...." I have then press the reset button on my circuit, but the dialog box just stays there which means nothing happened.
    I have measured the voltage between MCLR and GND and it is 5v?
    <img src="http://www.mecanique.co.uk/code-studio/loader/reset-circuit-small.gif">
    MikeTamu's Avatar
    MikeTamu Guest
    What OSC speed are you running at?
  1. Stupid simple question.....
    By chien_fu in forum mel PIC BASIC
    Last Post: - 23rd February 2010, 14:21
  2. Simple Timer question
    By jimseng in forum mel PIC BASIC Pro
    Last Post: - 25th September 2009, 00:12
  3. SIMPLE question
    Last Post: - 5th February 2008, 19:27
  4. really simple, dumb question
    By picster in forum mel PIC BASIC Pro
    Last Post: - 3rd March 2007, 23:02
  5. really simple adcin question
    By kitcat in forum mel PIC BASIC Pro
    Last Post: - 21st April 2006, 10:06
