Help GPS read with serin
Results 1 to 8 of 8
    G8RPI's Avatar
    G8RPI Guest
    Be careful if just counting characters. Some of the NMEA 0183 data strings have variable lengths. You need to check the specification for your device.
    I'd concurr on using the hardware serial UART and a crystal.
    Robert G8RPI.
    leinske's Avatar
    leinske Guest
    Thumbs up I have the solution
    Thanks evrerybody, i made my prototype for GPS reading and it works perfectly i give my code as somebody can use it for similar applications
    Best regards,
    Leinske
    ' Program to display returned value of a GPS on RB1
    ' LCD in 4-BIT mode PIC16F628 controller 4Mhz clock Fuse PWRT BODEN
    ' LCD should be connected as follows:
    ' LCD PIC
    ' DB4 PortA.0
    ' DB5 PortA.1
    ' DB6 PortA.2
    ' DB7 PortA.3
    ' RS PortA.4 (add 4.7K pullup resistor to 5 volts)
    ' E PortB.3
    ' RW Ground
    ' Vdd 5 volts
    ' Vss Ground
    ' Vo 20K potentiometer (or ground)
    ' DB0-3 No connect
    'GPS sentence: $GPRMC,192144.62,A,5041.6058,N,00412.6124,E,0.45,3 57.74,081205,,*0B
    CMCON = 7
    GPSin VAR PORTB.1
    SW VAR PORTB.5 'optional switch for Man Over Board keeps position on EEPROM when switched on
    TRISB.1=1 'define port B1 as input
    TRISB.5=1 'define port B5 as input
    TRISA.0=0
    TRISA.1=0
    TRISA.2=0
    TRISA.3=0
    TRISA.4=0
    TRISB.3=0
    PORTA=0
    PORTB=0
    'Allocate Variables for GPS:
    TimeOut CON 3000
    baudGPS CON 24764 '16572 + 8192 (bit 13)
    hh VAR BYTE 'hours
    mm VAR BYTE 'minutes
    knots VAR WORD 'speed in knots (units)
    knotsten VAR BYTE 'speed in knots (tens)
    course VAR WORD 'heading
    latdeg VAR BYTE 'degrees latitude
    latmin VAR BYTE 'minutes latitude
    NS VAR BYTE 'north or south
    londeg VAR BYTE 'degrees longitude
    lonmin VAR BYTE 'minutes longitude
    EO VAR BYTE 'east or west
    j VAR BYTE 'day
    m VAR BYTE 'month
    a VAR BYTE 'year
    fix VAR WORD 'GPS fix
    LCDOut $FE, 1 'Clear Screen
    LCDOut " POP CORN"
    LCDOut $fe,$c0
    LCDOut " WELCOME ABOARD"
    Pause 2000
    LCDOut " YOUR SKIPPER"
    LCDOut $fe,$c0
    LCDOut " ALAIN DE VOS"
    Pause 2000
    GPS: 'read GPS
    IF SW=1 Then 'switch for man over board
    GoTo mob
    EndIF
    SerIn2 GPSin,baudGPS,Timeout,Nogps,[wait("$GPRMC"),wait(","),DEC2 hh,DEC2 mm,wait(","),fix,wait(","),DEC2 latdeg,DEC2 latmin,wait(","),NS,wait(","),DEC3 londeg,DEC2 lonmin,wait(","),EO,wait(","),knots,wait("."),DEC2 knotsten,wait(","),DEC3 course,wait(","),DEC2 j,DEC2 m,DEC2 a]
    IF fix="V" Then 'if no GPS fix
    GoTo Nofix
    EndIF
    'write last valid into EEPROM
    Write 0,hh
    Write 1,mm
    Write 2,latdeg
    Write 3,latmin
    Write 4,NS
    Write 5,londeg
    Write 6,lonmin
    Write 7,EO
    Write 8,j
    Write 9,m
    Write 10,a
    GoTo LCD
    LCD:
    'normal display if fix ok
    LCDOut "SPEED :",knots,".",DEC2 knotsten," KNT"
    LCDOut $fe,$c0
    LCDOut "HEADING:",DEC3 course," DEG"
    Pause 3000
    LCDOut "LAT:",DEC2 latdeg,",",DEC2 latmin," ",NS
    LCDOut $fe,$c0
    LCDOut "LON:",DEC2 londeg,",",DEC2 lonmin," ",EO
    Pause 3000
    GoTo GPS
    'display if no gps is present
    Nogps:
    Pause 1000
    LCDOut " NO GPS"
    Pause 1000
    GoTo GPS
    'display if no gps fix
    Nofix:
    'read last valid from EEPROM
    Read 0,hh
    Read 1,mm
    Read 2,latdeg
    Read 3,latmin
    Read 4,NS
    Read 5,londeg
    Read 6,lonmin
    Read 7,EO
    Read 8,j
    Read 9,m
    Read 10,a
    Pause 1000
    LCDOut " NO GPS FIX"
    LCDOut $fe,$c0
    LCDOut " LAST VALID"
    Pause 2000
    LCDOut "DATE: ",DEC2 j,"-",DEC2 m,"-",DEC2 a
    LCDOut $fe,$c0
    LCDOut "TIME: ",DEC2 hh,":",DEC2 mm
    Pause 2000
    LCDOut $fe,$c0
    Pause 2000
    GoTo GPS
    mob: 'man over board
    Read 2,latdeg
    Read 3,latmin
    Read 4,NS
    Read 5,londeg
    Read 6,lonmin
    Read 7,EO
    Pause 1000
    LCDOut " MAN OVER BOARD"
    LCDOut $fe,$c0
    LCDOut " POSITION"
    Pause 2000
    LCDOut $fe,$c0
    Pause 2000
    GoTo GPS
    leinske, I notice 1 thing, I hope the MOB switch is a push button that can only be actuated 1 time or a push button switch with some kind of software flag to disable the EEPROM update after the first write as the actual MOB location will be over written. I would put some kind of flag that you must reset in a different way to maintain the MOB's actual location. Just a thought.......
    leinske's Avatar
    leinske Guest
    Lightbulb MOB switch
    Hi Dave,
    in fact the MOB switch is a 2 positions ON/OFF toggle switch, there is also a pull down resistor on portB.5.
    when MOB occures, the switch is set to ON then the program goes to the mob label, return to GPS label, test if switch is on if wel, loops to mob solong the switch is not set to off.
    The writing instructions are after the switch test routine, so there are no updates of de EEPROM during the MOB action, I think it's the simplest way to do it ;o)
    regards,
    Leinske
    Jul 2007
    Default lan lat
    Dear LEINSKE
    Thanks for the source code. I just had a problem with SERIN line now its works well
    Actualy I don't need to see on LCD . I catch all relevant fields of $GPRMC and I am sending by SEROUT2 command to PC by serial cable
    In your code I can catch only 4 digits of the lan and lat how can I catch all lan lat as is ?
    I add lanss and latss variables try to catch all strings I am loosing 0 (zero)
    3202.9876 I get 32.02 and 03412.3452 I get 34.12
    Haim Rodrik
    Default Please repost this to the GPS section.
    This post should be moved to the GPS thread I feel. It seems a good thread with useful code and it uses a different way of extracting the data fields than my old post in the GPS section.
    Cheers
    Brian
  1. Cleaning up code
    Last Post: - 2nd December 2009, 07:14
  2. GPS $GPRMC to PIC16F684. Need help with SERIN2
    Last Post: - 27th November 2009, 09:47
  3. SEROUT WORD variable problem
    Last Post: - 19th April 2009, 11:20
  4. Q: using MCLR for Input on 12F683
    By picster in forum mel PIC BASIC Pro
    Last Post: - 31st January 2009, 15:25
  5. Changing declared variables names on the fly
    Last Post: - 16th December 2006, 06:34
