Port pin problems
Results 1 to 3 of 3
    sgreelish's Avatar
    sgreelish Guest
    Default Port pin problems
    Using a 17C756 with select case statements to set pins on a give port. Each time the routine executes with in the case structure ( if then else also) to set (1 or HIGH) all pins on the port are reset (0 or LOW). If a pin is set one one port say PORTD it does not effect other pin of ports PORTF, PORTE and so on. I have tried simple implied Let command s( Var = 1) and the HIGH Var form. Neither works.
    The pin names are defined variables which are then used in the body of the code.
    Anybody know whats going on.
    If you post your actual code and definitions, then folk might have a chance identifying what your problem is, or trying to replicate it, otherwise it's kinda stabbing in the dark.
    sgreelish's Avatar
    sgreelish Guest
    I turns out that the 17C756 defauts to A/D analog inputs on the two ports I was working with. Melabs set me straight.
    Everything now works fine.
  1. Is this a K Type sensor?
    Last Post: - 21st November 2009, 13:55
  2. DS1820 with 16f688
    Last Post: - 23rd May 2009, 05:07
  3. Microcontroller with 2 way paging application problem
    Last Post: - 20th April 2007, 17:27
  4. Another RTC, DS1287
    Last Post: - 12th December 2006, 17:07
  5. port/ pin explanation 16F877
    By emmett brown in forum mel PIC BASIC Pro
    Last Post: - 27th August 2006, 01:07
