Current Calculation Method
Results 1 to 5 of 5
    Jun 2005
    Wisconsin
    Question Current Calculation Method
    I'm a hobbyist with a fairly basic question. Its something I've never had to deal with.
    In many of my projects, I have installed a 7805 by default knowing that I wouldn't ever need more than 1A of power. However I'm at the point were I would like to switch to a 78L05 to save on space. How does one go about calculating whether the 100mA the 78L05 will be enough?
    Mar 2006
    INDIA
    You can use dc-dc converter as small as 2mm X 2mm
    http://www.linear.com/ltmagazine/LTMag_V16N2_Jul06.pdf
    Jun 2005
    Wisconsin
    You didn't understand the question.
    I'm trying to figure out my current draw based on the my schematic.
    Bombay, India
    The method I would choose is to be absolutely sure. What you do is to measure the current with the worst case load scenario and build your power supply for this. The other technique, which I think you are asking about, is to check the datasheets for the parts involved and check the Icc requirement of each. The total current required will tell you if the 78L05 can handle this.
    Jerson
    The easy way...
    Cut the +5v Supply lead, insert a DVM to measure your current consumption. Write some code to switch-ON (or work) every possible peripheral that draws current. Add a little as a 'safety margin'. Personally I never run any 78L05 over 50mA which allows for a 100% safety margin. They do get hot when you run them near their maximum, and I don't like anything getting hot in designs...
  1. Reducing PIC current to as low as possible...
    By FromTheCockpit in forum mel PIC BASIC Pro
    Last Post: - 18th November 2009, 05:28
  2. Replies: 8
    Last Post: - 5th May 2009, 21:10
  3. 16F628A current high during sleep
    Last Post: - 9th October 2006, 11:21
  4. Current Meter
    By mikefox in forum mel PIC BASIC Pro
    Last Post: - 18th September 2006, 07:15
  5. measuring current from a photo diode
    By mischl in forum mel PIC BASIC Pro
    Last Post: - 13th November 2005, 15:42
