vb6 to pic basic
Results 1 to 8 of 8
    Mar 2004
    No this is not a max232 in the circuit, just direct connect, I have not tried any other baud rate (this is the default in the radio and works fine with simple vb6 program
    Well, if there's not a max232 in the middle, then you might be back to the 5v serial comm not being enough to drive the receivers inputs, which might want the +12/-12v that a real rs232 serial port would give you. The PicBasic code looks fine to me, no errors I can see. Hope this helps in some small way.
    JDG
    Mar 2004
    Thanks for that but I have found that using a 10MHz crystal I had the fuse bit for XT set instead of HS. Thanks to Charles in another thread that I picked up on my mistake.
    DOH! Good find...you're not alone on that one!
    JDG
  1. Loop with two motor and 2 sensors
  2. Automatic VB6 to pic serial connection
    By arniepj in forum Code Examples
    Last Post: - 10th January 2008, 08:57
  3. using AND as an IF statement
    By dw_pic in forum mel PIC BASIC
    Last Post: - 8th June 2006, 19:05
  4. Pic 18F4550 & VB6
    By lentz in forum USB
    Last Post: - 5th April 2006, 01:55
  5. The Ultimate PIC Basic
    By picnaut in forum PBP Wish List
    Last Post: - 9th November 2004, 23:10
