Pic18F452
Results 1 to 23 of 23
Thread: Pic18F452
    I can't tell anything about ADCOM As it doesn't exist, but let's try with ADCON0
    If you plan to use PBP ADCIN, use my PicMultiCalc software. It make things easy. Let's say your OSC=20 MHz, your analog source impedance is 1K and you want to make a 10 Bit conversion, you need to add those DEFINEs at the top of your code
    DEFINE ADC_BITS 10    ' ADCIN resolution  (Bits)
    DEFINE ADC_CLOCK 2    ' ADC clock source  (Fosc/32)
    DEFINE ADC_SAMPLEUS 3 ' ADC sampling time (uSec)
    ADC_CLOCK 2 refer to ADCS1:ADCS0 bits (ADCON0<7:6>)
    Sure you could even use the usual Frc and set your Sampling time to 50uSec and it will cover almost every possible situation.
    Even by using the PicMultiCalc, you'll need to set the ADFM bit in ADCON1 register. Yeah i didn't include this in the software as Microchip change their mind in almost every new PIC. Maybe One day... maybe.
    Now, if you plan to NOT use ADCIN, you must do everything manually. Here's ashort example... OK OK it looks huge but...
            '   PIC configuration fuses
            asm
    		__CONFIG    _CONFIG1H, _HS_OSC_1H
                                    ; HS osc (20 MHz
    		__CONFIG    _CONFIG2L, _BOR_ON_2L & _BORV_27_2L & _PWRT_ON_2L
                                    ; Enable Brown out voltage detect
                                    ; Brown out voltage threshold 2.7 Volt
    		__CONFIG    _CONFIG2H, _WDT_OFF_2H
                                    ; Disable watch dog timer
    		__CONFIG    _CONFIG3H, _CCP2MX_OFF_3H
                                    ; Use default PORTC.1 for CCP2
    		__CONFIG    _CONFIG4L, _STVR_ON_4L & _LVP_OFF_4L & _DEBUG_OFF_4L
                                    ; enable stack overflow
                                    ; disable low-voltage programming mode
                                    ; disable background debugger
    		__CONFIG    _CONFIG5L, _CP0_OFF_5L & _CP1_OFF_5L & _CP2_OFF_5L & _CP3_OFF_5L
                                    ; disable code protect (user block)
    		__CONFIG    _CONFIG5H, _CPB_OFF_5H & _CPD_OFF_5H
                                    ; disable code protect (boot block)
    		__CONFIG    _CONFIG6L, _WRT0_OFF_6L & _WRT1_OFF_6L & _WRT2_OFF_6L & _WRT3_OFF_6L
                                    ; disable write protect (user block)
    		__CONFIG    _CONFIG6H, _WRTC_OFF_6H & _WRTB_OFF_6H & _WRTD_OFF_6H
                                    ; disable Write protect CONFIG regs
                                    ; disable write protect boot block
                                    ; disable rite protect Data EE
    		__CONFIG    _CONFIG7L, _EBTR0_OFF_7L
                                    ; Disable table Read protect user block
    		__CONFIG    _CONFIG7H, _EBTRB_OFF_7H
                                    ; Disable Read protect boot block enable
            endasm
            '       Hardware configuration
            DEFINE OSC 20
                    '   Adc
            ADCON0 = %10000001                  ' Conversion clock = Fosc/32
                                                ' AN0 selected
                                                ' turn on ADC
            ADCON1 = %110001110                 ' right justified results
                                                ' PORTA.0 as analog, all other to digital
            '       Hardware assignment
                    '   LCD
            DEFINE LCD_DREG PORTD               ' LCD data port
            DEFINE LCD_DBIT 4                   ' LCD data starting bit 0 or 4
            DEFINE LCD_RSREG PORTD              ' LCD register select port
            DEFINE LCD_RSBIT 2                  ' LCD register select bit
            DEFINE LCD_EREG PORTD               ' LCD enable port
            DEFINE LCD_EBIT 3                   ' LCD enable bit
            DEFINE LCD_BITS 4                   ' LCD bus size 4 or 8
            DEFINE LCD_LINES 2                  ' Number lines on LCD
            DEFINE LCD_COMMANDUS 2000           ' Command delay time in us
            DEFINE LCD_DATAUS 50                ' Data delay time in us
            '       Alias definition
                    '   ADC
            GoDone  var ADCON0.2                ' use to start/stop/check
                                                '       AD conversion
            ADON    VAR ADCON0.0                ' use to start/shut-off ADC
            '       Variable definition
            @AdResult = ADRESL
            AdResult        var word EXT        ' Store ADC result
            '       Software constants
            ADC_SampleUs    con 3               ' ADC sampling time
            '       Program Start here
            Pause 500                           ' LCD start up delay
    Start:
                    '       A/D conversion
            adon = 1                            ' turn on ADC
            pauseus adc_sampleus                ' Wait minimum sampling time
            godone = 1                          ' start conversion
            while godone : wend                 ' check if finished
            adon = 0                            ' turn off ADC
                    '       Show result on LCD
            lcdout $FE,1, "Result=:", dec adresult
                                                ' show result on LCD
            pause 250
            goto stART
    Sep 2005
    Switzerland
    Thanks Mister_E,
    your explanation is well done but it's not easy to get it into
    my head (hard).
    I'll try to make some practical tests.
    I'll take also a look to your prg.
    Lotondo
    Jul 2007
    Default Help Meeeee
    Well, hi everybody ...
    It seems that you all know the basics of how to manage a 2x16 LCD with the famous 18f452 but i don't ..:'(
    I really need to make it work for a project, but here's my problem, i have a pic trainer with the LCD configured to work with the high nibble data bus but it has the RS-->RB2, RE-->RB3 ,R/W-->gnd, and D4-D7 -->RB4-RB7 as you see all in the same portb, i gave on trying it myself. So please could anybody give me a code to display one message on the LCD. I wouldn't mind if you have it for a 16f877 as i have that one too. I know i may be asking too much, but please help me. Thanx
    just in case one of you has mercy on my soul... my email is [email protected]
    Jul 2007
    Default About ADC_CLOCK
    Mister e, you said
    "ADC_CLOCK 2 refer to ADCS1:ADCS0 bits (ADCON0<7:6>)"
    I would like to know where I can find information about this. Or ,maybe easier, can you explain how ADC_CLOCK is "translated" to Focs/32. Is this simply the decimal value of ADCS1:ADCS0 bits?
    Thanks!
    GrandPa...
    You can find the information you seek and it's all explained in great detail in the DATASHEET for the PIC you are using. Download it from www.microchip.com and study...
    Tip: NEVER program a PIC without first studying it's Datasheet.
    evilpic...
    No, you're not asking too much, but this is very basic stuff that you should be capable of figuring for yourself.
    Take a look at the LCDOUT command located here... http://www.melabs.com/resources/pbpmanual/
    Scroll down until you find the DEFINE statements and change them accordingly for your preferred hardware connections.
    Tip: NEVER program anything without first studying the compiler manual.
    Jul 2007
    Question Let me explain....
    Thank's Melanie, but I've actually read the datasheet and use it currently. I'm actually setting the ADCON0 register directly instead if using the define.
    My question is very specific about the DEFINE ADC_CLOCK.
    What I don't understand is the meaning of the parameter (number) after the define:
    In the book you have :
    DEFINE ADC_CLOCK 3 'ADC clock source (rc = 3)
    WHY does 3 mean RC clock ?
    And
    Why does 2 mean Fosc/32
    After reading the datasheet, I came to the conclusion that this number is the binary values of ADCS0:ADCS2 (PIC18F4620 here). But I wanted to make sure. So let me ask again:
    ----> Is this the decimal value of ADCS0:ADCS2 ?
    (btw: I'm french, trying my best to explain my question)
    J-P
  1. PIC18f452 blinking led ?
    By iugmoh in forum General
    Last Post: - 7th March 2008, 14:12
  2. Serial communication with pic18f452
    By tamersoss in forum mel PIC BASIC Pro
    Last Post: - 30th December 2007, 21:27
  3. communicating pic18f452 with pic16f877a
    Last Post: - 13th July 2007, 19:54
  4. Dealy in turn ON of PIC18F452
    By genesis in forum General
    Last Post: - 13th October 2006, 10:40
  5. Replies: 5
    Last Post: - 26th March 2006, 19:26
