Pic18F452
Results 1 to 23 of 23
Thread: Pic18F452
    Dec 2005
    Thank you very much MikeTamu i just assumed that PBP took care of all that for me as there is no reference to it in the pbp manual.
    Thanks again.
    Sep 2003
    INDIA
    Default Please Help !
    I am having similar problems trying to get an LCD working on EasyPIC3 from Mikroelectronika Board using PBP and 18F452 MCU. Although i can get the LED to blink , I cannot get the LCD to work. Can you help.
    EasyPIC3 Development Board Configuration -
    D4 - RB4
    D5 - RB5
    D6 - RB6
    D7 - RB7
    RS - RB2
    E - RB3
    RW - GND
    My Code:
    DEFINE OSC 8
    ' HARDWARE DEFINES
    ' Define LCD pins
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE LCD_DREG PORTB
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_RSBIT 2
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 3
    TRISA = %111111 'INITIALIZE PORT DIRECTIONS
    TRISB = %00000000
    TRISC = %10101001
    TRISD = %00000011
    TRISE = %00000111
    Adcon1 = 7 ' Set PORTA DIGITAL
    INTCON2.7=1 ' DISABLE Pull-Up's
    PAUSE 500
    Lcdout $fe , 1 , "EasyPIC3 DEV"
    LCDOut $FE,$C0, "Board v1A"
    PAUSE 2000
    Be sure you set HS_OSC fuse before programming your PIC
    Sep 2003
    INDIA
    Hello,
    Thanks for coming to my help once again, yes the Crystal fuse is set properly as i have a small led blink rotuine after this display , which works properly.
    The LCD works with MikroBasic Compiler, But does not come on with PBP.
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    Because you are running at 8MHz, try including one or both of these and increasing the times as shown here
    DEFINE LCD_COMMANDUS 4000
    DEFINE LCD_DATAUS 100
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Sep 2003
    INDIA
    Default Thank you Steve,
    Hi Steve,
    Your inputs in a different thread solved my problem. The code was OK just that LVP fuse was enabled.
    Just disabled it and there I could see what I had to on my LCD.
    Thanks.
    regards
    GOOD!
    Kind of thing to remember i guess!
  1. PIC18f452 blinking led ?
    By iugmoh in forum General
    Last Post: - 7th March 2008, 15:12
  2. Serial communication with pic18f452
    By tamersoss in forum mel PIC BASIC Pro
    Last Post: - 30th December 2007, 22:27
  3. communicating pic18f452 with pic16f877a
    Last Post: - 13th July 2007, 20:54
  4. Dealy in turn ON of PIC18F452
    By genesis in forum General
    Last Post: - 13th October 2006, 11:40
  5. Replies: 5
    Last Post: - 26th March 2006, 20:26
