Came across: LP2966
Single chip, provides 3.3 and 3.6v outputs, with up to 150mA on each.
This isn't enough for the GSM module, but if I'm only reporting position via GSM every so often, I could possible use the regulator to charge a capacitor, and then the capacitor to drive the module. As long as the module is off a lot more than it is on, this should work...
Ben
