3.6v regulation
Results 1 to 18 of 18
Thread: 3.6v regulation
    barkerben's Avatar
    barkerben Guest
    The PIC will run at 3.6v. However, my circuit contains 3 main modules:
    PIC 16F628
    GSM module (GR47)
    GPS module (ZX4120)
    The PIC can run at a very wide range of voltages (2.2-5.5 I think)
    The GSM module can run from 3.4-6v (including ripple)
    According to the datasheet, the GPS can run from 3.3v +-5%. However, in the same data sheet, it is specified that it can run up to 3.6v.
    In this case I can run eveything from a 3.6v supply, which would be good :-)
    Maybe I should email the manufacturers and ask them about the descrepancy...
    Ben
    Sep 2003
    Vermont
    Who makes the GPS module?
    barkerben's Avatar
    barkerben Guest
    It is sold by Crownhill (same people who run the forum it seems). I think it is made by Nemerix - they certainly make the internal chipset, although I'm not entirely sure :-)
    Ben
    barkerben's Avatar
    barkerben Guest
    Looking through the data sheets, I might be able to get away with running eveything from 3.3v (which would make eveything very nice and simple. 3.3v regulators easy to get, everything running at same voltage)- it all depends on whether the GSM module (GR47 from erricson) can run at this level. It says 3.4v minimum, but it might work :-p
    Ben
    Sep 2003
    Vermont
    Quote Originally Posted by barkerben
    Ben
    It's the ZX 4125 from Wonde Proud. It will operate up to....get this...3.6 volts! I am using one for a remote logging device. The input pins should not go above 3.3 volts. Slip a shottky diode in series with the PIC B+ line to drop it a bit for the I/Os. The GSM unit will be very finicky about voltage sags, so feed it well!
