40 kHz wave
Results 1 to 13 of 13
Thread: 40 kHz wave
    RUBiksCUbe's Avatar
    RUBiksCUbe Guest
    Alright I didnt read over the datasheet enough but I still don't understand how I know what "Tosc" is in the PWM period equation. I found a confusing chart on page 273 that says that in HS mode, which is what my 18F252 is in with a 20 MHz oscillator, Tosc has a range of 40 to 250 ns. How do I find what it is? Once I know how to correctly find Tosc I can solve the equation and calculate what I need to set PR2 to.
    I know that in order to generate a 40 kHz signal I need to generate a square wave with a pulse duration of 25 microseconds.
    Ok,
    The formula in the datasheet for the PIC18FXX2:
    PWM period = [(PR2) + 1] • 4 • TOSC • (TMR2 prescale value)
    and 1/PWM period = frequency so in my case:
    1/PWM period = 40,000
    PWM period = .000025 (25 microseconds)
    So my equation should be
    .000025 = [(PR2) + 1] • 4 • TOSC • (TMR2 prescale value)
    Since TMR2 prescale is 1, I can rearrange it so that (PR2), the unknown, is on one side:
    (20MHz / (4 * TMR2 prescale value * 40KHz)) - 1= PR2.
    Solve it all out...
    PR2 = 124
    And it works!
    Thanks everyone!
    In case anyone in the future needs to use the hardware PWMs and has no idea what to set PR2 to, use this equation:
    (Oscillator speed / (4 * TMR2 prescale value * Desired Output)) - 1= PR2.
  1. To Generate Sine Wave Using PCPWM of PIC18F4331 (Issue)
    By Cyborg in forum mel PIC BASIC Pro
    Last Post: - 22nd March 2014, 13:39
  2. 40 KHz burst
    By aherrera in forum mel PIC BASIC Pro
    Last Post: - 25th November 2009, 22:36
  3. What's the best way to output 30 to 40 kHz from a 12F683 pin?
    By fizyxman in forum mel PIC BASIC Pro
    Last Post: - 1st June 2009, 00:08
  4. Sine wave
    By Darrenmac in forum mel PIC BASIC Pro
    Last Post: - 18th May 2009, 03:31
  5. PIC 16F877 I2C communications
    By sigmoideng in forum General
    Last Post: - 13th July 2007, 10:28
