40 kHz wave
Results 1 to 13 of 13
Thread: 40 kHz wave
    RUBiksCUbe's Avatar
    RUBiksCUbe Guest
    Woah I didn't know about the HPWM command. I'm still learning PBP. It seems like it will do the trick in my case.
    I don't like using 555s because they heat up and their output changes.
    I think that for a 40kHz square wave I need to say:
    HPWM 1,127,40000
    Right?
    Nop! HPWM will not do the job in this case... look in the PBP manual for the specific limitation on different crystal speed.
    in your case you must write directly to the internal register related by the PWM module. look section 11 of the datasheet and look to the Milestag's example. I'm not a fan of HPWM myself too.
    555's are not as this bad.. it's working great but it's still a RC oscillator ... like the PIC internal one. So both will shift a litlle bit with the temperature variation.
    There's still some easy circuit to build with some CMOS inverter OR Route the CLKOUT of the PIC to a frequency divider OR.... OR...
    RUBiksCUbe's Avatar
    RUBiksCUbe Guest
    How do you write stuff to the internal registers? I've tried to set up my PIC as a counter before but I didn't know how to, and the COUNT command didn't really work too well. I'm looking through my PICs datasheet (12F683) and I don't understand what it's talking about. What is the CCP1CON register? It mentions it a lot in the PWM section.
    It says that in order to set the PWM period I need to the PR2 register. How/What do I write?
    Sep 2005
    Dayton, Ohio
    Read my earlier post again. I already showed you exactly how to write to those registers, and the values you need for 40KHz.
    Just make sure that those are the identical register names.
    Jim Robertson
    "MilesTag" DIY Lasertag
    www.lasertagparts.com/mtdesign.htm
    Dayton, Ohio
    RUBiksCUbe's Avatar
    RUBiksCUbe Guest
    I tried your code (the register names are the same) but it didn't work. The datasheet tells me to "Make the CCP1 pin an output by clearing the
    TRISIO<2> bit." and your code didn't do that. How do I clear a bit?
    clear bit n => bit n=0
    set bit n => bit n=1
    clear bit 2 of TRISIO => TRISIO.2=1
    the Register value will be different for each crystal speed. You can run the F683 with the internal 8 MHZ or lower, 4MHZ is rthe default speed. Refer to the OSCCON table
    RUBiksCUbe's Avatar
    RUBiksCUbe Guest
    I think it really helps when making writing code for a PIC when the PIC actually works. >:0. I was using a dead PIC. When I saw that A.0 was putting out a constant .5 volts and A.1 was putting out around 4 I realized that it might be the PICs fault. I tried a simple blinking program and the PIC is indeed dead. I'm switching over to the more powerfull (and faster) 18F252 running at 20 MHz.
  1. To Generate Sine Wave Using PCPWM of PIC18F4331 (Issue)
    By Cyborg in forum mel PIC BASIC Pro
    Last Post: - 22nd March 2014, 13:39
  2. 40 KHz burst
    By aherrera in forum mel PIC BASIC Pro
    Last Post: - 25th November 2009, 22:36
  3. What's the best way to output 30 to 40 kHz from a 12F683 pin?
    By fizyxman in forum mel PIC BASIC Pro
    Last Post: - 1st June 2009, 00:08
  4. Sine wave
    By Darrenmac in forum mel PIC BASIC Pro
    Last Post: - 18th May 2009, 03:31
  5. PIC 16F877 I2C communications
    By sigmoideng in forum General
    Last Post: - 13th July 2007, 10:28
