40 kHz wave
Results 1 to 13 of 13
Thread: 40 kHz wave
    RUBiksCUbe's Avatar
    RUBiksCUbe Guest
    Default 40 kHz wave
    I need to pulse an LED signal at 40 kHz for an IR project, but
    PULSOUT A1, 40
    didn't work on a 4 MHz 12F683, and the manual said that a pic running at 4 MHz has a PULSOUT period of 10 us. The datasheet (http://pdf.alldatasheet.com/datashee.../PNA4614M.html) of the IR detector I am using said that the typical signal width is 200 us.
    Does the PIC not actually pulse out at 10 us intervals?
    Wink with a little help from peripherals
    Hi, Rubik
    a 555 running at 40 khz would easily solve your headache ...without any program timing difficulties ...
    Sep 2005
    Dayton, Ohio
    Default The peripherals are already built-in!
    Just use the PIC12F683's internal hardware PWM peripheral. This way you can easily generate the 40KHz, turn it on and off, adjust the duty cycle and it runs in the background. The datasheet will show you exactly how to set it up.
    Personally I don't like using the HPWM command in PB Pro because its too limited. It's easier to do it by manually setting the registers.
    This is exactly how I generate the 40KHz IR for my lasertag systems.
    'register setup (this is for a 16F684, so it may need to be modified slightly for your chip)
    PR2 = 49 'PWM Period 40K=49
    CCPR1L = 10 'PWM Duty Cycle
    T2CON = 4 'Timer2 = ON; Prescale = 1:1
    CCP1CON = 0 'PWM module off
    'generate 1ms 40KHz pulse
    CCP1CON = 12 'PWM ON
    PauseUS 1000
    CCP1CON = 0 'PWM OFF
    Jim Robertson
    "MilesTag" DIY Lasertag
    www.lasertagparts.com/mtdesign.htm
    Dayton, Ohio
    RUBiksCUbe's Avatar
    RUBiksCUbe Guest
    Woah I didn't know about the HPWM command. I'm still learning PBP. It seems like it will do the trick in my case.
    I don't like using 555s because they heat up and their output changes.
    I think that for a 40kHz square wave I need to say:
    HPWM 1,127,40000
    Right?
    Nop! HPWM will not do the job in this case... look in the PBP manual for the specific limitation on different crystal speed.
    in your case you must write directly to the internal register related by the PWM module. look section 11 of the datasheet and look to the Milestag's example. I'm not a fan of HPWM myself too.
    555's are not as this bad.. it's working great but it's still a RC oscillator ... like the PIC internal one. So both will shift a litlle bit with the temperature variation.
    There's still some easy circuit to build with some CMOS inverter OR Route the CLKOUT of the PIC to a frequency divider OR.... OR...
    RUBiksCUbe's Avatar
    RUBiksCUbe Guest
    How do you write stuff to the internal registers? I've tried to set up my PIC as a counter before but I didn't know how to, and the COUNT command didn't really work too well. I'm looking through my PICs datasheet (12F683) and I don't understand what it's talking about. What is the CCP1CON register? It mentions it a lot in the PWM section.
    It says that in order to set the PWM period I need to the PR2 register. How/What do I write?
  1. To Generate Sine Wave Using PCPWM of PIC18F4331 (Issue)
    By Cyborg in forum mel PIC BASIC Pro
    Last Post: - 22nd March 2014, 14:39
  2. 40 KHz burst
    By aherrera in forum mel PIC BASIC Pro
    Last Post: - 25th November 2009, 23:36
  3. What's the best way to output 30 to 40 kHz from a 12F683 pin?
    By fizyxman in forum mel PIC BASIC Pro
    Last Post: - 1st June 2009, 01:08
  4. Sine wave
    By Darrenmac in forum mel PIC BASIC Pro
    Last Post: - 18th May 2009, 04:31
  5. PIC 16F877 I2C communications
    By sigmoideng in forum General
    Last Post: - 13th July 2007, 11:28
