Nokia 3310 LCD
Results 1 to 4 of 4
Thread: Nokia 3310 LCD
    barkerben's Avatar
    barkerben Guest
    Default Nokia 3310 LCD
    I've come across a nokia 3310 LCD. However, it is mising the whote strip at the bottom and the connector with the solder pads. If I hold the glass at the right angle, I can see the ITO tracks and pads. I suspect the missing white strip means no driver. Am I correct? Can I use it?
    Cheers,
    Ben
    Feb 2004
    Michigan, USA
    Got a picture to post of the thing?
    barkerben's Avatar
    barkerben Guest
    Here are some closeups of the screen. You can just see the ITO traces on the glass.
    Feb 2004
    Michigan, USA
    I would say that you do not have an on board driver on that display. If it were chip on glass (COG) I'd expect to see a "bump" on the back somewhere. This would be the driver chip covered in a coating of epoxy sealant or compound.
  1. Interfacing Nokia 3310 Lcd Using PIC16f877a
    By reianjim in forum mel PIC BASIC Pro
    Last Post: - 27th December 2009, 14:54
  2. Nokia 3310 LCD
    By muddy0409 in forum mel PIC BASIC Pro
    Last Post: - 2nd April 2008, 21:19
  3. Nokia 3310 display text
    Last Post: - 26th August 2007, 04:39
  4. nokia 3310 lcd!! (help)
    By ibra in forum mel PIC BASIC Pro
    Last Post: - 3rd August 2007, 13:20
  5. Interface Nokia 3310 LCD
    By joseph Degorio in forum GSM
    Last Post: - 25th February 2007, 15:06
