Starting PC from PIC
Results 1 to 8 of 8
    Oct 2003
    Australia
    Talking
    Yeah I've done this.. very neat program too!
    Two things I found, to get you started.
    1. Use the pic and relay in parallel with the soft Soft -Off wire. I used an omron G5V-1 SPDT type, but you could use a reed relay instead. I know you dont want to use a relay.. but for a couple of bucks... you'll get total isoltation!
    2. Depending on your ap, you may need feed back from the pc (floppy power cable example) so the pic doesn't turn the pc off, when it's actually turning it on. Opto isolator for this is a must!
    Good luck
    J
    Italy
    Automatically restart upon power fail
    Go into the PC BIOS and under the menu POWER see if you can find
    the option "Restore on AC Power Loss".
    Best regards,
    Luciano
  1. Replies: 24
    Last Post: - 2nd October 2017, 11:35
  2. Send data PIC to PC
    By konter in forum Off Topic
    Last Post: - 25th December 2009, 22:04
  3. Replies: 67
    Last Post: - 8th December 2009, 02:27
  4. HSERIN & Interupts (aka controlling PIC programs from a remote PC)
    Last Post: - 17th June 2009, 14:46
  5. Replies: 11
    Last Post: - 12th July 2008, 02:36
