OK, So the second options is still using the CASE SELECT method is it?
Does this mean that the statement will look as follows:
ie, does the MaskSwitch.1 represent Case 1 value, MaskSwitch.2 represent Case 2 etc etc?Code:Button1 Var PORTC.0 Button2 Var PORTC.1 Button3 Var PORTC.2 Button4 Var PORTC.6 Main: MaskSwitch=0 If PORTC.0 Then MaskSwitch.0=1 If PORTC.1 Then MaskSwitch.1=1 If PORTC.2 Then MaskSwitch.2=1 If PORTC.6 Then MaskSwitch.3=1 Select Case MaskSwitch Case 0 If Button1 = 1 Then Gosub Procedure_Button1 If Button1 = 0 THEN EndIf Case 1 If Button2 = 1 Then Gosub Procedure_Button2 If Button2 = 0 THEN EndIf Case 2 If Button3 = 1 Then Gosub Procedure_Button3 If Button3 = 0 THEN EndIf .......
Many thanks again,
